Ana içeriğe geç
HTC Flyer MicroUSB Port Replacement
Neye ihtiyacın var
  1. HTC Flyer MicroUSB Port Replacement, Back Cover: adım 1, 3 resimden 1. HTC Flyer MicroUSB Port Replacement, Back Cover: adım 1, 3 resimden 2. HTC Flyer MicroUSB Port Replacement, Back Cover: adım 1, 3 resimden 3.
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
  2. HTC Flyer MicroUSB Port Replacement: adım 2, 3 resimden 1. HTC Flyer MicroUSB Port Replacement: adım 2, 3 resimden 2. HTC Flyer MicroUSB Port Replacement: adım 2, 3 resimden 3.
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
  3. HTC Flyer MicroUSB Port Replacement: adım 3, 3 resimden 1. HTC Flyer MicroUSB Port Replacement: adım 3, 3 resimden 2. HTC Flyer MicroUSB Port Replacement: adım 3, 3 resimden 3.
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
  4. HTC Flyer MicroUSB Port Replacement: adım 4, 2 resimden 1. HTC Flyer MicroUSB Port Replacement: adım 4, 2 resimden 2.
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
  5. HTC Flyer MicroUSB Port Replacement, Battery: adım 5, 2 resimden 1. HTC Flyer MicroUSB Port Replacement, Battery: adım 5, 2 resimden 2.
    • Gently unfold the black tape along the top that covers the cable attachment points.
    • Leave the tape partially attached so that it can be easily re-attached.
  6. HTC Flyer MicroUSB Port Replacement: adım 6, 3 resimden 1. HTC Flyer MicroUSB Port Replacement: adım 6, 3 resimden 2. HTC Flyer MicroUSB Port Replacement: adım 6, 3 resimden 3.
    • Use the tip of a spudger as a lever to disconnect the four cable connectors.
    • Gently pull out these cables after releasing the back piece.
  7. HTC Flyer MicroUSB Port Replacement: adım 7, 1 resimden 1.
    • Remove the single 2.5mm Torx T5 screw holding the battery down along the top side.
  8. HTC Flyer MicroUSB Port Replacement: adım 8, 3 resimden 1. HTC Flyer MicroUSB Port Replacement: adım 8, 3 resimden 2. HTC Flyer MicroUSB Port Replacement: adım 8, 3 resimden 3.
    • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
    • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
    • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
  9. HTC Flyer MicroUSB Port Replacement, MicroUSB Port: adım 9, 1 resimden 1.
    • Use a spudger to unclip the the wires attached to the power jack
    • The clips have a white or black relief tab that, when pressed, releases the wires.
  10. HTC Flyer MicroUSB Port Replacement: adım 10, 2 resimden 1. HTC Flyer MicroUSB Port Replacement: adım 10, 2 resimden 2.
    • Remove the two 2.5mm Torx T5 screws from both sides of the power jack panel.
  11. HTC Flyer MicroUSB Port Replacement: adım 11, 2 resimden 1. HTC Flyer MicroUSB Port Replacement: adım 11, 2 resimden 2.
    • Gently remove the power jack panel.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Joshua
185 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 8-5, Leahy Fall 2014 USF Tampa, Team 8-5, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S8G5
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 55
Her zaman: 1,449
