Ana içeriğe geç
HTC Fortress Camera Replacement
Neye ihtiyacın var
  1. HTC Fortress Camera Replacement, Battery: adım 1, 2 resimden 1. HTC Fortress Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover of the device by sliding it upward.
    • You may need to remove the phone stylus first.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Fortress Camera Replacement: adım 2, 2 resimden 1. HTC Fortress Camera Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pulling it away from the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Fortress Camera Replacement, Camera: adım 3, 2 resimden 1. HTC Fortress Camera Replacement, Camera: adım 3, 2 resimden 2.
    • Remove the top 2 screws on the back of the phone with the T4 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Fortress Camera Replacement: adım 4, 3 resimden 1. HTC Fortress Camera Replacement: adım 4, 3 resimden 2. HTC Fortress Camera Replacement: adım 4, 3 resimden 3.
    • Remove the camera panel by hand (black cover above the battery slot).
    • Be careful; there is a cable attached underneath the case. It does detach, just pull on it carefully.
    • During reassembly, put the cable back in by holding the black piece slightly above its slot and using the spudger to gently press the end of the cable back into its fitting. Then, insert the black piece so it is flush with the black panel again.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Fortress Camera Replacement: adım 5, 3 resimden 1. HTC Fortress Camera Replacement: adım 5, 3 resimden 2. HTC Fortress Camera Replacement: adım 5, 3 resimden 3.
    • Work the metal camera casing off by slowly prying up the sides using the spudger.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Fortress Camera Replacement: adım 6, 2 resimden 1. HTC Fortress Camera Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the tweezers to pull the camera straight out of the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lucas David
540 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-13, Maness Spring 2013 Cal Poly, Team 4-13, Maness Spring 2013 üyesi
CPSU-MANESS-S13S4G13
4 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 730
