Ana içeriğe geç
HTC Freestyle Primary Buttons Replacement
Neye ihtiyacın var
  1. HTC Freestyle Primary Buttons Replacement, Remove back cover: adım 1, 2 resimden 1. HTC Freestyle Primary Buttons Replacement, Remove back cover: adım 1, 2 resimden 2.
    • Apply pressure to the dark plastic casing and slide the casing downward, off of the phone.
  2. HTC Freestyle Primary Buttons Replacement, Open plastic flap.: adım 2, 2 resimden 1. HTC Freestyle Primary Buttons Replacement, Open plastic flap.: adım 2, 2 resimden 2.
    • Fold the plastic flap open.
  3. HTC Freestyle Primary Buttons Replacement, Reveal the battery: adım 3, 2 resimden 1. HTC Freestyle Primary Buttons Replacement, Reveal the battery: adım 3, 2 resimden 2.
    • Pull on the red tab to slide the battery out.
    • Take out the battery.
    • Replace with new battery.
  4. HTC Freestyle Primary Buttons Replacement, Remove screws from plastic flap: adım 4, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the five screws anchoring the plastic flap to the phone.
    • One of the five screws may be hidden beneath a "Void" sticker to the right of the serial label.
  5. HTC Freestyle Primary Buttons Replacement, Remove plastic flap from phone: adım 5, 1 resimden 1.
    • Once the screws are removed from the plastic flap, the piece should easily come out.
  6. HTC Freestyle Primary Buttons Replacement, Remove circuiting panel: adım 6, 2 resimden 1. HTC Freestyle Primary Buttons Replacement, Remove circuiting panel: adım 6, 2 resimden 2.
    • After the screws are removed, fold circuit panel upwards, exposing the phone's primary buttons.
    • In order to remove the circuit board you must disconnect the labeled component.
  7. HTC Freestyle Primary Buttons Replacement, Remove primary buttons: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Once the back side of the buttons are exposed, they will fall out either by punching them out from the front side, or by using tweezers to pull them out of the back.
Sonuç
Ryan Curtis
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 8-3, Leahy Fall 2014 USF Tampa, Team 8-3, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S8G3
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 506
