Ana içeriğe geç
HTC HD2 Earpiece Speaker Replacement
Neye ihtiyacın var
  1. HTC HD2 Earpiece Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Earpiece Speaker Replacement: adım 2, 2 resimden 1. HTC HD2 Earpiece Speaker Replacement: adım 2, 2 resimden 2.
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Earpiece Speaker Replacement, Midframe: adım 3, 2 resimden 1. HTC HD2 Earpiece Speaker Replacement, Midframe: adım 3, 2 resimden 2.
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Earpiece Speaker Replacement: adım 4, 2 resimden 1. HTC HD2 Earpiece Speaker Replacement: adım 4, 2 resimden 2.
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
  5. HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: adım 5, 3 resimden 1. HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: adım 5, 3 resimden 2. HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: adım 5, 3 resimden 3.
    • Disconnect the small speaker cable from its socket on the motherboard.
    • Remove the earpiece speaker from the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathan Puchalski
813 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-55, Amido Spring 2011 Cal Poly, Team 24-55, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G55
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 4,916
