Ana içeriğe geç
HTC HD2 Midframe Replacement
Neye ihtiyacın var
    1. HTC HD2 Midframe Replacement, Battery: adım 1, 1 resimden 1.
      • Carefully pull the rear cover from the back of the phone.
      • Place a finger beneath the small lip on the left side of the battery.
      FixBot'a Sor
      Yorum Ekle
    2. HTC HD2 Midframe Replacement: adım 2, 2 resimden 1. HTC HD2 Midframe Replacement: adım 2, 2 resimden 2.
      • Lay the phone down on it's screen.
      • Lift up on the lip and pull the battery from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC HD2 Midframe Replacement, Midframe: adım 3, 2 resimden 1. HTC HD2 Midframe Replacement, Midframe: adım 3, 2 resimden 2.
      • Remove the four black 3.5mm T5 screws from the back of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. HTC HD2 Midframe Replacement: adım 4, 2 resimden 1. HTC HD2 Midframe Replacement: adım 4, 2 resimden 2.
      • Insert the flat end of a spudger between the midframe and the display.
      • Slide the spudger along the seam between the frame and the display.
      • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
      • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
      • As it releases, pull the midframe away from the phone.
      • The volume control tab may fall off during removal. It can be easily reattached.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sam Luedloff
727 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-55, Amido Spring 2011 Cal Poly, Team 24-55, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G55
5 Üyeler
96 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 9,303
