Ana içeriğe geç
HTC HD2 Motherboard Replacement
Neye ihtiyacın var
    1. HTC HD2 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
      • Carefully pull the rear cover from the back of the phone.
      • Place a finger beneath the small lip on the left side of the battery.
      FixBot'a Sor
      Yorum Ekle
    2. HTC HD2 Motherboard Replacement: adım 2, 2 resimden 1. HTC HD2 Motherboard Replacement: adım 2, 2 resimden 2.
      • Lay the phone down on it's screen.
      • Lift up on the lip and pull the battery from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC HD2 Motherboard Replacement, Midframe: adım 3, 2 resimden 1. HTC HD2 Motherboard Replacement, Midframe: adım 3, 2 resimden 2.
      • Remove the four black 3.5mm T5 screws from the back of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. HTC HD2 Motherboard Replacement: adım 4, 2 resimden 1. HTC HD2 Motherboard Replacement: adım 4, 2 resimden 2.
      • Insert the flat end of a spudger between the midframe and the display.
      • Slide the spudger along the seam between the frame and the display.
      • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
      • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
      • As it releases, pull the midframe away from the phone.
      • The volume control tab may fall off during removal. It can be easily reattached.
      FixBot'a Sor
      Yorum Ekle
    1. HTC HD2 Motherboard Replacement, Vibrator: adım 5, 2 resimden 1. HTC HD2 Motherboard Replacement, Vibrator: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Set the phone down on its screen.
      • Using tweezers, unplug the small vibrator connector from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. HTC HD2 Motherboard Replacement: adım 6, 1 resimden 1.
      • Pull the vibrator motor from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC HD2 Motherboard Replacement, Earpiece Speaker: adım 7, 3 resimden 1. HTC HD2 Motherboard Replacement, Earpiece Speaker: adım 7, 3 resimden 2. HTC HD2 Motherboard Replacement, Earpiece Speaker: adım 7, 3 resimden 3.
      • Disconnect the small speaker cable from its socket on the motherboard.
      • Remove the earpiece speaker from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC HD2 Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. HTC HD2 Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
      • Remove five T5 Torx screws from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. HTC HD2 Motherboard Replacement: adım 9, 3 resimden 1. HTC HD2 Motherboard Replacement: adım 9, 3 resimden 2. HTC HD2 Motherboard Replacement: adım 9, 3 resimden 3.
      • Disconnect the flash cable from its socket at the bottom of the motherboard.
      • Carefully pull the flash cable from its slot in the side of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. HTC HD2 Motherboard Replacement: adım 10, 3 resimden 1. HTC HD2 Motherboard Replacement: adım 10, 3 resimden 2. HTC HD2 Motherboard Replacement: adım 10, 3 resimden 3.
      • Pull the camera flash and cover off of the board.
      • You may need to peel back the sticker that sits behind the battery.
      • Work carefully. Excessive force can damage the camera or motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. HTC HD2 Motherboard Replacement: adım 11, 3 resimden 1. HTC HD2 Motherboard Replacement: adım 11, 3 resimden 2. HTC HD2 Motherboard Replacement: adım 11, 3 resimden 3.
      • Now locate the coaxial bluetooth cable that connects the top and bottom boards of the phone.
      • Use tweezers to pop both ends of the cable from the boards and remove it completely.
      FixBot'a Sor
      Yorum Ekle
    5. HTC HD2 Motherboard Replacement: adım 12, 3 resimden 1. HTC HD2 Motherboard Replacement: adım 12, 3 resimden 2. HTC HD2 Motherboard Replacement: adım 12, 3 resimden 3.
      • Now find the AP FPC, one of the smallest connectors on the bottom board.
      • Pop the small black tab up using tweezers, then unplug the cable.
      FixBot'a Sor
      Yorum Ekle
    6. HTC HD2 Motherboard Replacement: adım 13, 3 resimden 1. HTC HD2 Motherboard Replacement: adım 13, 3 resimden 2. HTC HD2 Motherboard Replacement: adım 13, 3 resimden 3.
      • This step is pretty much irreversible, so do not do this unless you absolutely have to.
      • Remember peeling back part of that big sticker in the middle? Now you get to take it all the way off.
      • This may take some time, and the use of the tweezers, but keep at it until the whole sticker is off.
      FixBot'a Sor
      Yorum Ekle
    7. HTC HD2 Motherboard Replacement: adım 14, 1 resimden 1.
      • Now find the GPS board in the upper left hand corner of the phone.
      • Disconnect the white cable from its socket on the motherboard.
      • The cable does not need to be unplugged from the main bottom board.
      • This cable is connected to the underside of the bottom board. If it is detached, be sure to reconnect it before reassembling the phone.
      FixBot'a Sor
      Yorum Ekle
    8. HTC HD2 Motherboard Replacement: adım 15, 3 resimden 1. HTC HD2 Motherboard Replacement: adım 15, 3 resimden 2. HTC HD2 Motherboard Replacement: adım 15, 3 resimden 3.
      • If this step does not progress easily, check to see that there are no screws still holding the board in place.
      • With the cable removed, pop the GPS board out of the phone using tweezers.
      FixBot'a Sor
      Yorum Ekle
    9. HTC HD2 Motherboard Replacement: adım 16, 3 resimden 1. HTC HD2 Motherboard Replacement: adım 16, 3 resimden 2. HTC HD2 Motherboard Replacement: adım 16, 3 resimden 3.
      • Using a spudger, begin to pry the copper colored board in the middle away from the phone to loosen it.
      • Also pry the small piece that runs under where the volume selector is on the full phone.
      FixBot'a Sor
      Yorum Ekle
    10. HTC HD2 Motherboard Replacement: adım 17, 3 resimden 1. HTC HD2 Motherboard Replacement: adım 17, 3 resimden 2. HTC HD2 Motherboard Replacement: adım 17, 3 resimden 3.
      • There is a connecter cable under the main board, so do not pull it all the way off right away.
      • Gently pop both the top and bottom boards off of the phone, and turn them over to the left
      FixBot'a Sor
      Yorum Ekle
    11. HTC HD2 Motherboard Replacement: adım 18, 2 resimden 1. HTC HD2 Motherboard Replacement: adım 18, 2 resimden 2.
      • With the back of the main board exposed, flip up the little brown lever at the end of the connector and unplug the final cable that connects it to the main board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Nathan Puchalski
813 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-55, Amido Spring 2011 Cal Poly, Team 24-55, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G55
5 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 16,187
