Ana içeriğe geç
HTC Hero Camera Replacement
Neye ihtiyacın var
  1. HTC Hero Camera Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Hero Camera Replacement: adım 2, 1 resimden 1.
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Hero Camera Replacement: adım 3, 1 resimden 1.
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Hero Camera Replacement: adım 4, 2 resimden 1. HTC Hero Camera Replacement: adım 4, 2 resimden 2.
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Hero Camera Replacement, Camera: adım 5, 3 resimden 1. HTC Hero Camera Replacement, Camera: adım 5, 3 resimden 2. HTC Hero Camera Replacement, Camera: adım 5, 3 resimden 3.
    • Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Hero Camera Replacement: adım 6, 2 resimden 1. HTC Hero Camera Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free. Repeat for the opposite side.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Hero Camera Replacement: adım 7, 2 resimden 1. HTC Hero Camera Replacement: adım 7, 2 resimden 2.
    • Pull the released camera enclosure away from the motherboard until it is completely free.
    FixBot'a Sor
    Yorum Ekle
  8. HTC Hero Camera Replacement: adım 8, 2 resimden 1. HTC Hero Camera Replacement: adım 8, 2 resimden 2.
    • Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Max Brown
139 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G26
5 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 1,692
