Ana içeriğe geç
HTC Hero Motherboard Replacement
Neye ihtiyacın var
  1. HTC Hero Motherboard Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Hero Motherboard Replacement: adım 2, 1 resimden 1.
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Hero Motherboard Replacement: adım 3, 1 resimden 1.
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Hero Motherboard Replacement: adım 4, 2 resimden 1. HTC Hero Motherboard Replacement: adım 4, 2 resimden 2.
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Hero Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. HTC Hero Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Release the two ribbon cables using a plastic opening tool.
    • Gently pry up the pop connectors used to attach the ribbon cables to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Hero Motherboard Replacement: adım 6, 2 resimden 1. HTC Hero Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Hero Motherboard Replacement: adım 7, 2 resimden 1. HTC Hero Motherboard Replacement: adım 7, 2 resimden 2.
    • Gently lift the motherboard out of the front enclosure once the screws are removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Rosalind Villalvazo
100 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G26
5 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 1,876
