Ana içeriğe geç
HTC Incredible 2 Micro SD Card Replacement
  1. HTC Incredible 2  Micro SD Card Replacement, Disassembling HTC Incredible 2 Back Panel: adım 1, 2 resimden 1. HTC Incredible 2  Micro SD Card Replacement, Disassembling HTC Incredible 2 Back Panel: adım 1, 2 resimden 2.
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Incredible 2  Micro SD Card Replacement: adım 2, 1 resimden 1.
    • Remove the rear panel from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Incredible 2  Micro SD Card Replacement, Micro SD Card: adım 3, 2 resimden 1. HTC Incredible 2  Micro SD Card Replacement, Micro SD Card: adım 3, 2 resimden 2.
    • Use your fingertip to push inward on the SD card until you hear a click.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Incredible 2  Micro SD Card Replacement: adım 4, 3 resimden 1. HTC Incredible 2  Micro SD Card Replacement: adım 4, 3 resimden 2. HTC Incredible 2  Micro SD Card Replacement: adım 4, 3 resimden 3.
    • Remove your finger. The SD card is no longer being held in place.
    • Grasp it with two fingers and pull it towards you to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ka Tong
131 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S11G53
5 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 620
