Ana içeriğe geç
HTC Incredible 2 Battery Replacement
  1. HTC Incredible 2 Battery Replacement, Disassembling HTC Incredible 2 Back Panel: adım 1, 2 resimden 1. HTC Incredible 2 Battery Replacement, Disassembling HTC Incredible 2 Back Panel: adım 1, 2 resimden 2.
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Incredible 2 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the rear panel from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Incredible 2 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Incredible 2 Battery Replacement: adım 4, 2 resimden 1. HTC Incredible 2 Battery Replacement: adım 4, 2 resimden 2.
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jonathan Morsch
394 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S11G53
5 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 885
