Ana içeriğe geç
HTC Incredible 2 SIM Card Replacement
  1. HTC Incredible 2 SIM Card Replacement, Disassembling HTC Incredible 2 Back Panel: adım 1, 2 resimden 1. HTC Incredible 2 SIM Card Replacement, Disassembling HTC Incredible 2 Back Panel: adım 1, 2 resimden 2.
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. HTC Incredible 2 SIM Card Replacement: adım 2, 1 resimden 1.
    • Remove the rear panel from the phone.
  3. HTC Incredible 2 SIM Card Replacement, Battery: adım 3, 1 resimden 1.
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
  4. HTC Incredible 2 SIM Card Replacement: adım 4, 2 resimden 1. HTC Incredible 2 SIM Card Replacement: adım 4, 2 resimden 2.
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  5. HTC Incredible 2 SIM Card Replacement, SIM Card: adım 5, 2 resimden 1. HTC Incredible 2 SIM Card Replacement, SIM Card: adım 5, 2 resimden 2.
    • Apply pressure with your fingertip to the pressure clip beneath the SIM card.
    • While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
  6. HTC Incredible 2 SIM Card Replacement: adım 6, 2 resimden 1. HTC Incredible 2 SIM Card Replacement: adım 6, 2 resimden 2.
    • Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
Sonuç
William Slope
130 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S11G53
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 1,234
