Ana içeriğe geç
HTC Maple 100 Back Panel Replacement
Neye ihtiyacın var
  1. HTC Maple 100 Back Panel Replacement, Battery: adım 1, 1 resimden 1.
    • First remove the back cover of your phone to expose the battery.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Maple 100 Back Panel Replacement: adım 2, 1 resimden 1.
    • Turn the phone over.
    • Push forward on the battery with your thumb.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Maple 100 Back Panel Replacement: adım 3, 2 resimden 1. HTC Maple 100 Back Panel Replacement: adım 3, 2 resimden 2.
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Maple 100 Back Panel Replacement, Back Panel: adım 4, 2 resimden 1. HTC Maple 100 Back Panel Replacement, Back Panel: adım 4, 2 resimden 2.
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Maple 100 Back Panel Replacement: adım 5, 1 resimden 1.
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Maple 100 Back Panel Replacement: adım 6, 3 resimden 1. HTC Maple 100 Back Panel Replacement: adım 6, 3 resimden 2. HTC Maple 100 Back Panel Replacement: adım 6, 3 resimden 3.
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Andrew Van Meter
24 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-29, Maness Fall 2011 Cal Poly, Team 20-29, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G29
4 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 1,067
