Ana içeriğe geç
HTC Maple 100 Front Panel Replacement
Neye ihtiyacın var
    1. HTC Maple 100 Front Panel Replacement, Battery: adım 1, 1 resimden 1.
      • First remove the back cover of your phone to expose the battery.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Maple 100 Front Panel Replacement: adım 2, 1 resimden 1.
      • Turn the phone over.
      • Push forward on the battery with your thumb.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Maple 100 Front Panel Replacement: adım 3, 2 resimden 1. HTC Maple 100 Front Panel Replacement: adım 3, 2 resimden 2.
      • Take the battery out by lifting it upwards.
      • When reassembling, make sure that the battery contacts match up.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Maple 100 Front Panel Replacement, Back Panel: adım 4, 2 resimden 1. HTC Maple 100 Front Panel Replacement, Back Panel: adım 4, 2 resimden 2.
      • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Maple 100 Front Panel Replacement: adım 5, 1 resimden 1.
      • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Maple 100 Front Panel Replacement: adım 6, 3 resimden 1. HTC Maple 100 Front Panel Replacement: adım 6, 3 resimden 2. HTC Maple 100 Front Panel Replacement: adım 6, 3 resimden 3.
      • Insert the plastic opening tool along the seams at different points to it pry the clips off.
      • This may require a bit of force. The USB port cover may fall off in this step.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Maple 100 Front Panel Replacement, Motherboard: adım 7, 2 resimden 1. HTC Maple 100 Front Panel Replacement, Motherboard: adım 7, 2 resimden 2.
      • Remove the one 3.3mm Phillips #00 screw.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Maple 100 Front Panel Replacement: adım 8, 2 resimden 1. HTC Maple 100 Front Panel Replacement: adım 8, 2 resimden 2.
      • Use your finger or the plastic opening tool to unclip the board.
      • Be aware of the ribbon cable connected to the motherboard inside the phone.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Maple 100 Front Panel Replacement: adım 9, 2 resimden 1. HTC Maple 100 Front Panel Replacement: adım 9, 2 resimden 2.
      • Peel off the yellow piece of tape from the phone.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Maple 100 Front Panel Replacement: adım 10, 3 resimden 1. HTC Maple 100 Front Panel Replacement: adım 10, 3 resimden 2. HTC Maple 100 Front Panel Replacement: adım 10, 3 resimden 3.
      • Flip up the retaining flap with your fingernail or a plastic opening tool.
      • Pull on the ribbon cable gently with your fingers.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Maple 100 Front Panel Replacement: adım 11, 2 resimden 1. HTC Maple 100 Front Panel Replacement: adım 11, 2 resimden 2.
      • Split apart the motherboard and front panel.
      • Remove the other yellow piece of tape off of the end of the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Maple 100 Front Panel Replacement: adım 12, 2 resimden 1. HTC Maple 100 Front Panel Replacement: adım 12, 2 resimden 2.
      • Gently pull on the ribbon cable to separate the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Maple 100 Front Panel Replacement, Keyboard: adım 13, 2 resimden 1. HTC Maple 100 Front Panel Replacement, Keyboard: adım 13, 2 resimden 2.
      • Remove the four 1.9 mm Phillips #00 screws.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Maple 100 Front Panel Replacement: adım 14, 1 resimden 1.
      • Peel back the tape gently.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Maple 100 Front Panel Replacement: adım 15, 1 resimden 1.
      • Remove the board gently.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Maple 100 Front Panel Replacement: adım 16, 2 resimden 1. HTC Maple 100 Front Panel Replacement: adım 16, 2 resimden 2.
      • Remove the keys carefully.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Maple 100 Front Panel Replacement, Front Panel: adım 17, 3 resimden 1. HTC Maple 100 Front Panel Replacement, Front Panel: adım 17, 3 resimden 2. HTC Maple 100 Front Panel Replacement, Front Panel: adım 17, 3 resimden 3.
      • Using the Plastic Opening Tool, pry out the LCD screen and remove with fingers.
      • Be gentle because the LCD screen is fragile.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Maple 100 Front Panel Replacement: adım 18, 3 resimden 1. HTC Maple 100 Front Panel Replacement: adım 18, 3 resimden 2. HTC Maple 100 Front Panel Replacement: adım 18, 3 resimden 3.
      • Use the Plastic Opening Tool to remove the internal ear speaker.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ekip
Cal Poly, Team 20-29, Maness Fall 2011 Cal Poly, Team 20-29, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G29
4 Üyeler
81 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 1,072
