Giriş
To replace the speakers of the HTC MyTouch 4G, the Motherboard must be removed in order to get to the speakers. This guide will show how to remove the Motherboard and replace the speakers.
Neye ihtiyacın var
Place the prying tool into the notch at the bottom of the case and pull up to remove.
Use the plastic prying tool in the upper left-hand corner notch of the battery to remove.
Remove the two T5x5mm Screws with the T5 Torx Screw driver.
Remove the one Phillips screw with the Phillips #00 Screwdriver.
Use the plastic opening tools to remove the back case.
There are four T5x5mm screws. Use the T5 Torx Screwdriver to remove them.
Using the plastic opening tools, remove the Wifi antenna.
There are three button ribbons on the phone that need to be pulled down off of the case.
With the plastic opening tools, pull the button ribbons down away from the frame without completely removing them.
After the motherboard is removed, the speaker is now able to be replaced.
Use the plastic opening tools to pull out the old speaker and replace it with the new one.
