Ana içeriğe geç
HTC One Front Panel Replacement
Neye ihtiyacın var
  1. HTC One Front Panel Replacement, Front Panel: adım 1, 2 resimden 1. HTC One Front Panel Replacement, Front Panel: adım 1, 2 resimden 2.
    • Use the plastic opening tool to scrape and loosen the adhesive from the crease surrounding the screen.
    • A good place to start is the volume button and it should come right out as you pry.
  2. HTC One Front Panel Replacement: adım 2, 1 resimden 1.
    • Wedge the plastic opening tool into the crack around the screen on the top, left and right sides.
    • This step can be sped up by using a heat gun or iOpener to heat up the glue.
  3. HTC One Front Panel Replacement: adım 3, 2 resimden 1. HTC One Front Panel Replacement: adım 3, 2 resimden 2.
    • Once the screen has been loosened on the top, left and right edges, lift the screen.
    • The screen will stay on a hinge until the final step.
  4. HTC One Front Panel Replacement: adım 4, 1 resimden 1.
    • Gently remove the volume button. Using the plastic opening tool, loosen the back panel of the phone. Begin in the space where the battery was and work around the phone, following the crease of the back panel.
  5. HTC One Front Panel Replacement: adım 5, 2 resimden 1. HTC One Front Panel Replacement: adım 5, 2 resimden 2.
    • Pry the back open once loose and lift. The back panel will come off with time.
  6. HTC One Front Panel Replacement: adım 6, 3 resimden 1. HTC One Front Panel Replacement: adım 6, 3 resimden 2. HTC One Front Panel Replacement: adım 6, 3 resimden 3.
    • Remove all the #000 screws with a #000 Phillips screw driver
    • Some screws are hidden by tape so remove the tape and check for screws.
  7. HTC One Front Panel Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to get underneath the mother board to lift.
    • Lift slowly because it is not fully disconnected yet.
  8. HTC One Front Panel Replacement: adım 8, 2 resimden 1. HTC One Front Panel Replacement: adım 8, 2 resimden 2.
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it).
    • Lift the camera out of the motherboard.
  9. HTC One Front Panel Replacement: adım 9, 2 resimden 1. HTC One Front Panel Replacement: adım 9, 2 resimden 2.
    • Lift the motherboard completely out of the phone. (may stay attached at the bottom by tape)
  10. HTC One Front Panel Replacement: adım 10, 2 resimden 1. HTC One Front Panel Replacement: adım 10, 2 resimden 2.
    • Use the blue opening tool to pry up the battery from the frame.
    • The battery is glued to the frame so you will have to put force.
    • Do not break the battery upon removal.
  11. HTC One Front Panel Replacement: adım 11, 3 resimden 1. HTC One Front Panel Replacement: adım 11, 3 resimden 2. HTC One Front Panel Replacement: adım 11, 3 resimden 3.
    • Remove the motherboard entirely if not done on step 9.
  12. HTC One Front Panel Replacement: adım 12, 2 resimden 1. HTC One Front Panel Replacement: adım 12, 2 resimden 2.
    • Remove the screws in the speaker at the bottom of the frame.
    • Lift the speaker out of the frame.
  13. HTC One Front Panel Replacement: adım 13, 1 resimden 1.
    • Lift the screen out of its hinge.
    • Replace the screen.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Jeremy
1.862 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-1, Blackwell Fall 2014 USF Tampa, Team 12-1, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S12G1
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Thanks for the tutorial. Not the most repair friendly device,! It took me 2,5 hours, so it's surely possible to do it faster than 10 hours ;)
Albert Zweistein - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 48
Her zaman: 18,691
