Giriş
Use this guide to replace the headphone jack/micro USB board in your HTC One M8.
Please note that your device may have a large amount of copper shielding and tape covering the back of the display assembly, as shown here. If this is the case, you'll need to gently remove it to get at the motherboard.
Neye ihtiyacın var
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
Press to eject the tray.
Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
Remove the two silver 2mm Phillips #00 screws securing the battery connector to the motherboard.
Use a plastic opening tool to gently pry up the battery connector.
71 farklı kişi bu kılavuzu tamamladı.
23 Yorum
Worked for me - though looks like I will need to reopen as there is a problem with the wifi antenna & bluetooth connection is weak
where can i buy
i dont have one from sprint or horizon.. Which one do i buy?
Anybody want a new battery and charging port? Ok, only slightly used as the repair failed. When I got everything back together the LCD/backlight won't come on. I could charge the battery fine and you can feel the device responding to touch so the sensors in the display are working, but the screen will not light up what so ever. Now after a 3rd attempt to disassemble and reassemble searching in vane to find a lose connection there's a new problem, when I connect the battery lead to the terminals the phone vibrates. The only way to make the phone stop vibrating is to disconnect the battery. I can only assume this phone is now toast so it would be a shame to toss the 2 new parts...
How much? I'm having issues with the charging port not connecting to the micro used well
