Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Use this guide to replace the headphone jack/micro USB board in your HTC One M8.
Please note that your device may have a large amount of copper shielding and tape covering the back of the display assembly, as shown here. If this is the case, you'll need to gently remove it to get at the motherboard.
  1. Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone. Press to eject the tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
  2. Remove the SIM card tray assembly from the HTC One M8.
    • Remove the SIM card tray assembly from the HTC One M8.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  3. Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone. Press to eject the tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
  4. Remove the microSD card tray assembly from the HTC One M8.
    • Remove the microSD card tray assembly from the HTC One M8.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
  5. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  6. Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles. Refer to the iOpener guide for info on how to use the iOpener.
    • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
    • Refer to the iOpener guide for info on how to use the iOpener.
  7. Use a plastic opening tool to gently peel up the lower speaker grille. The adhesive is messy, and can be removed using Goo-gone. The adhesive is messy, and can be removed using Goo-gone.
    • Use a plastic opening tool to gently peel up the lower speaker grille.
    • The adhesive is messy, and can be removed using Goo-gone.
  8. Use a plastic opening tool to gently peel up the upper speaker grille. Use a plastic opening tool to gently peel up the upper speaker grille.
    • Use a plastic opening tool to gently peel up the upper speaker grille.
  9. Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the four black 4 mm T5 Torx screws from the bottom.
  10. Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly. A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device. Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
    • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
    • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Significant force may be required to pry the casing apart.
  11. Remove the two silver 2mm Phillips #00 screws securing the battery connector to the motherboard. Use a plastic opening tool to gently pry up the battery connector.
    • Remove the two silver 2mm Phillips #00 screws securing the battery connector to the motherboard.
    • Use a plastic opening tool to gently pry up the battery connector.
  12. Use a spudger to disconnect the two ZIF connectors. Use the flat end of a spudger to disconnect the black antenna cable. Use a set of tweezers to pull the two ribbon cables free of the ZIF connectors.
    • Use a spudger to disconnect the two ZIF connectors.
    • Use the flat end of a spudger to disconnect the black antenna cable.
    • Use a set of tweezers to pull the two ribbon cables free of the ZIF connectors.
  13. Remove the single silver 4mm T5 Torx screw securing the headphone jack/micro USB board. You may need to gently bend the small ribbon cable out of the way to get to the screw. Use a pair of tweezers or a plastic opening tool to gently pry the headphone jack/micro USB board up and out of the phone.
    • Remove the single silver 4mm T5 Torx screw securing the headphone jack/micro USB board.
    • You may need to gently bend the small ribbon cable out of the way to get to the screw.
    • Use a pair of tweezers or a plastic opening tool to gently pry the headphone jack/micro USB board up and out of the phone.
Sonuç
69 farklı kişi bu kılavuzu tamamladı.
Michael Gonzalez
4.166 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-9, Maness Spring 2015 Cal Poly, Team 5-9, Maness Spring 2015 üyesi
CPSU-MANESS-S15S5G9
4 Üyeler
18 adet Kılavuz yazıldı
23 Yorum
Worked for me - though looks like I will need to reopen as there is a problem with the wifi antenna & bluetooth connection is weak
Timothy Cockle - Yanıt
where can i buy
Sheraz Hussain - Yanıt
i dont have one from sprint or horizon.. Which one do i buy?
Vik De Brandt - Yanıt
Anybody want a new battery and charging port? Ok, only slightly used as the repair failed. When I got everything back together the LCD/backlight won't come on. I could charge the battery fine and you can feel the device responding to touch so the sensors in the display are working, but the screen will not light up what so ever. Now after a 3rd attempt to disassemble and reassemble searching in vane to find a lose connection there's a new problem, when I connect the battery lead to the terminals the phone vibrates. The only way to make the phone stop vibrating is to disconnect the battery. I can only assume this phone is now toast so it would be a shame to toss the 2 new parts...
spepperdine - Yanıt
How much? I'm having issues with the charging port not connecting to the micro used well
Jeremy Hunton -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 23
Son 30 gün: 73
Her zaman: 65,525
