Ana içeriğe geç
HTC One Max Fingerprint Sensor Replacement
Neye ihtiyacın var
    1. HTC One Max Fingerprint Sensor Replacement, Back Case: adım 1, 1 resimden 1.
      • Lift back cover while pressing highlighted release switch towards the center of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One Max Fingerprint Sensor Replacement: adım 2, 2 resimden 1. HTC One Max Fingerprint Sensor Replacement: adım 2, 2 resimden 2.
      • Remove the four white stickers in each corner that cover the Tri-Wing screws.
      • Remove the white sticker near the buttons that control the volume.
      • Remove the white sticker near the SIM card.
      • Remove the big white sticker with the bar-code in the center of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. HTC One Max Fingerprint Sensor Replacement: adım 3, 1 resimden 1.
      • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
      • Disconnect the cable near the volume buttons.
      FixBot'a Sor
      Yorum Ekle
    4. HTC One Max Fingerprint Sensor Replacement: adım 4, 2 resimden 1. HTC One Max Fingerprint Sensor Replacement: adım 4, 2 resimden 2.
      • Use the small plastic opening tool to pry between the screen and the rear case.
      FixBot'a Sor
      Yorum Ekle
    1. HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: adım 5, 2 resimden 1. HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
      • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Andrey Sklyar
452 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-3, Blackwell Fall 2014 USF Tampa, Team 11-3, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S11G3
4 Üyeler
63 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 1,614
