Giriş
You will learn how to replace a faulty microphone on an HTC One Max in this guide.
Parçalar
Lift back cover while pressing highlighted release switch towards the center of the phone.
Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
Use a plastic tool to remove the ribbon cable.
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
Remove the two 2.8 mm Phillips #000 screws from the metal plate near the bottom of the phone.
3 farklı kişi bu kılavuzu tamamladı.
