Giriş
In this guide you will learn how to replace the motherboard in the HTC One Max.
Neye ihtiyacın var
Lift back cover while pressing highlighted release switch towards the center of the phone.
Bu adımda kullanılan alet:Tweezers$4.99
Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
Use a plastic tool to remove the ribbon cable.
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
6 farklı kişi bu kılavuzu tamamladı.
