Ana içeriğe geç
HTC One Mini 2 Back Plate Replacement
Neye ihtiyacın var
  1. HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: adım 1, 3 resimden 1. HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: adım 1, 3 resimden 2. HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: adım 1, 3 resimden 3.
    • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
    • Set the cardholders aside.
  2. HTC One Mini 2 Back Plate Replacement: adım 2, 1 resimden 1.
    • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
  3. HTC One Mini 2 Back Plate Replacement, Front Plate: adım 3, 3 resimden 1. HTC One Mini 2 Back Plate Replacement, Front Plate: adım 3, 3 resimden 2. HTC One Mini 2 Back Plate Replacement, Front Plate: adım 3, 3 resimden 3.
    • Use a metal spudger to pry up the left edge of the upper grey front plate.
    • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
    • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
    • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
  4. HTC One Mini 2 Back Plate Replacement: adım 4, 2 resimden 1. HTC One Mini 2 Back Plate Replacement: adım 4, 2 resimden 2.
    • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
  5. HTC One Mini 2 Back Plate Replacement: adım 5, 2 resimden 1. HTC One Mini 2 Back Plate Replacement: adım 5, 2 resimden 2.
    • Use the plastic pry tool to pry around the edge of the phone.
    • Pry carefully around the card slots.
    • Slowly pull up from the right side of the screen like opening a book.
    • The plastic piece for the power button may fall out. Set it aside for reassembly.
    • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Caleb Kelsay
590 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-48, Amido Fall 2014 Cal Poly, Team 4-48, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S4G48
5 Üyeler
17 adet Kılavuz yazıldı
Bir Yorum
what is the black ribbon antenna on the front
deancvijic90 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 10,329
