Ana içeriğe geç
HTC One Mini 2 Dual Speakers Replacement
Neye ihtiyacın var
  1. HTC One Mini 2 Dual Speakers Replacement, Sim and MicroSD Card: adım 1, 3 resimden 1. HTC One Mini 2 Dual Speakers Replacement, Sim and MicroSD Card: adım 1, 3 resimden 2. HTC One Mini 2 Dual Speakers Replacement, Sim and MicroSD Card: adım 1, 3 resimden 3.
    • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
    • Set the cardholders aside.
    FixBot'a Sor
    Yorum Ekle
  2. HTC One Mini 2 Dual Speakers Replacement: adım 2, 1 resimden 1.
    • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
    FixBot'a Sor
    Yorum Ekle
  3. HTC One Mini 2 Dual Speakers Replacement, Front Plate: adım 3, 3 resimden 1. HTC One Mini 2 Dual Speakers Replacement, Front Plate: adım 3, 3 resimden 2. HTC One Mini 2 Dual Speakers Replacement, Front Plate: adım 3, 3 resimden 3.
    • Use a metal spudger to pry up the left edge of the upper grey front plate.
    • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
    • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
    • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
    FixBot'a Sor
    Yorum Ekle
  4. HTC One Mini 2 Dual Speakers Replacement: adım 4, 2 resimden 1. HTC One Mini 2 Dual Speakers Replacement: adım 4, 2 resimden 2.
    • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
    FixBot'a Sor
    Yorum Ekle
  5. HTC One Mini 2 Dual Speakers Replacement: adım 5, 2 resimden 1. HTC One Mini 2 Dual Speakers Replacement: adım 5, 2 resimden 2.
    • Use the plastic pry tool to pry around the edge of the phone.
    • Pry carefully around the card slots.
    • Slowly pull up from the right side of the screen like opening a book.
    • The plastic piece for the power button may fall out. Set it aside for reassembly.
    • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
    FixBot'a Sor
    Yorum Ekle
  6. HTC One Mini 2 Dual Speakers Replacement, Motherboard: adım 6, 2 resimden 1. HTC One Mini 2 Dual Speakers Replacement, Motherboard: adım 6, 2 resimden 2.
    • Peel off the long yellow pieces of tape on the right and left side of the copper plate.
    FixBot'a Sor
    Yorum Ekle
  7. HTC One Mini 2 Dual Speakers Replacement: adım 7, 1 resimden 1.
    • Starting from the copper plate, peel up all three woven, silver colored tapes using the spudger or narrow pry tool.
    FixBot'a Sor
    Yorum Ekle
  8. HTC One Mini 2 Dual Speakers Replacement: adım 8, 3 resimden 1. HTC One Mini 2 Dual Speakers Replacement: adım 8, 3 resimden 2. HTC One Mini 2 Dual Speakers Replacement: adım 8, 3 resimden 3.
    • Using the flat end of the spudger, pop up the white tabs on all ribbon cable connectors located to the left and right of the copper plate.
    • On the left side, pop the white tab up to the left. On the right, pop up to the right.
    • Carefully pull out the ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  9. HTC One Mini 2 Dual Speakers Replacement: adım 9, 3 resimden 1. HTC One Mini 2 Dual Speakers Replacement: adım 9, 3 resimden 2. HTC One Mini 2 Dual Speakers Replacement: adım 9, 3 resimden 3.
    • Using a Phillips #00 screwdriver, unscrew the two 1 mm screws from the bottom right corner of the motherboard that hold the power connector down.
    • Pop up the battery connector using the flat end of the spudger.
    FixBot'a Sor
    Yorum Ekle
  10. HTC One Mini 2 Dual Speakers Replacement: adım 10, 3 resimden 1. HTC One Mini 2 Dual Speakers Replacement: adım 10, 3 resimden 2. HTC One Mini 2 Dual Speakers Replacement: adım 10, 3 resimden 3.
    • Use the pointed end of the spudger to pop off the four antenna connectors. Three are located on the top left corner of the motherboard and one on the bottom right.
    FixBot'a Sor
    Yorum Ekle
  11. HTC One Mini 2 Dual Speakers Replacement: adım 11, 2 resimden 1. HTC One Mini 2 Dual Speakers Replacement: adım 11, 2 resimden 2.
    • Using the pointed end of the spudger, pull the wires for the rumble motor to the left to pull the connector out of the board.
    • The connector is very small and easy to break so take caution when pulling it out. Wiggling the wires as you pull to the left helps.
    FixBot'a Sor
    Yorum Ekle
  12. HTC One Mini 2 Dual Speakers Replacement: adım 12, 3 resimden 1. HTC One Mini 2 Dual Speakers Replacement: adım 12, 3 resimden 2. HTC One Mini 2 Dual Speakers Replacement: adım 12, 3 resimden 3.
    • Using a T5 torx screwdriver, remove four 2mm screws from the four corners of the motherboard.
    • Once the screws are removed, carefully pull the copper plated motherboard out.
    FixBot'a Sor
    Yorum Ekle
  13. HTC One Mini 2 Dual Speakers Replacement, Dual Speakers: adım 13, 2 resimden 1. HTC One Mini 2 Dual Speakers Replacement, Dual Speakers: adım 13, 2 resimden 2.
    • Use the flat end of the plastic spudger to pry the lower speaker out.
    • Holding the phone, pull the speaker to the right pulling the connector out of the board.
    • The connector is very small and easy to break so take caution when pulling it out. Wiggling the wires as you pull to the right helps.
    FixBot'a Sor
    Yorum Ekle
  14. HTC One Mini 2 Dual Speakers Replacement: adım 14, 1 resimden 1.
    • Using the narrow pry tool, pry the rear camera loose from the frame.
    FixBot'a Sor
    Yorum Ekle
  15. HTC One Mini 2 Dual Speakers Replacement, Top Speaker: adım 15, 2 resimden 1. HTC One Mini 2 Dual Speakers Replacement, Top Speaker: adım 15, 2 resimden 2.
    • Peel off the yellow tape covering the power button connector using the pointed end of the spudger.
    • Pop up the white tab on the ribbon cable connector for the power button located on the top right of the phone.
    • Carefully pull out the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  16. HTC One Mini 2 Dual Speakers Replacement: adım 16, 3 resimden 1. HTC One Mini 2 Dual Speakers Replacement: adım 16, 3 resimden 2. HTC One Mini 2 Dual Speakers Replacement: adım 16, 3 resimden 3.
    • Using a PH000 Phillips screwdriver, remove the four 1mm screws from the upper logic board.
    • Using the flat end of the spudger, pop the top speaker's plastic cover off.
    • Lift out the board with the camera and set it aside for reassembly.
    FixBot'a Sor
    Yorum Ekle
  17. HTC One Mini 2 Dual Speakers Replacement: adım 17, 1 resimden 1.
    • Using a 2 mm flat head screwdriver, pry out and remove the top speaker from the phone.
    • It is easy to pry the speaker apart rather than pry the whole thing out. So be careful to only pry on the metal plate and not the plastic siding of the speaker.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tad Steiner
177 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-48, Amido Fall 2014 Cal Poly, Team 4-48, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S4G48
5 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 3,166
