Ana içeriğe geç
HTC One Mini Battery Replacement
Neye ihtiyacın var
    1. HTC One Mini Battery Replacement, iOpener Heating: adım 1, 1 resimden 1.
      • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One Mini Battery Replacement, Remove Speaker Grills: adım 2, 1 resimden 1.
      • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
      • Remove the lower speaker cover.
      FixBot'a Sor
      Yorum Ekle
    3. HTC One Mini Battery Replacement, Remove Screw: adım 3, 3 resimden 1. HTC One Mini Battery Replacement, Remove Screw: adım 3, 3 resimden 2. HTC One Mini Battery Replacement, Remove Screw: adım 3, 3 resimden 3.
      • Remove the screw under the speaker cover using a T6 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. HTC One Mini Battery Replacement: adım 4, 3 resimden 1. HTC One Mini Battery Replacement: adım 4, 3 resimden 2. HTC One Mini Battery Replacement: adım 4, 3 resimden 3.
      • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
      • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
      FixBot'a Sor
      Yorum Ekle
    5. HTC One Mini Battery Replacement, Separate Rear Case: adım 5, 2 resimden 1. HTC One Mini Battery Replacement, Separate Rear Case: adım 5, 2 resimden 2.
      • Remove the rear case from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC One Mini Battery Replacement, Remove Screws: adım 6, 3 resimden 1. HTC One Mini Battery Replacement, Remove Screws: adım 6, 3 resimden 2. HTC One Mini Battery Replacement, Remove Screws: adım 6, 3 resimden 3.
      • Remove the two Phillips screws securing the battery connector.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One Mini Battery Replacement: adım 7, 2 resimden 1. HTC One Mini Battery Replacement: adım 7, 2 resimden 2.
      • Disconnect the battery by prying the metal cover straight up.
      FixBot'a Sor
      Yorum Ekle
    3. HTC One Mini Battery Replacement, Remove screws: adım 8, 3 resimden 1. HTC One Mini Battery Replacement, Remove screws: adım 8, 3 resimden 2. HTC One Mini Battery Replacement, Remove screws: adım 8, 3 resimden 3.
      • Remove two Phillips screws.
      • The screw on the upper right corner secures a tiny golden washer. Remove this washer.
      FixBot'a Sor
      Yorum Ekle
    4. HTC One Mini Battery Replacement, Remove Screws: adım 9, 3 resimden 1. HTC One Mini Battery Replacement, Remove Screws: adım 9, 3 resimden 2. HTC One Mini Battery Replacement, Remove Screws: adım 9, 3 resimden 3.
      • Remove the two small black Phillips screws.
      FixBot'a Sor
      Yorum Ekle
    5. HTC One Mini Battery Replacement, Remove Screws: adım 10, 3 resimden 1. HTC One Mini Battery Replacement, Remove Screws: adım 10, 3 resimden 2. HTC One Mini Battery Replacement, Remove Screws: adım 10, 3 resimden 3.
      • Remove two more Phillips screws.
      FixBot'a Sor
      Yorum Ekle
    6. HTC One Mini Battery Replacement, Remove protective foil.: adım 11, 3 resimden 1. HTC One Mini Battery Replacement, Remove protective foil.: adım 11, 3 resimden 2. HTC One Mini Battery Replacement, Remove protective foil.: adım 11, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
      FixBot'a Sor
      Yorum Ekle
    7. HTC One Mini Battery Replacement: adım 12, 2 resimden 1. HTC One Mini Battery Replacement: adım 12, 2 resimden 2.
      • Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps.
      • To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
      FixBot'a Sor
      Yorum Ekle
    8. HTC One Mini Battery Replacement: adım 13, 3 resimden 1. HTC One Mini Battery Replacement: adım 13, 3 resimden 2. HTC One Mini Battery Replacement: adım 13, 3 resimden 3.
      • Peel off the silver strip with your tweezers.
      • Using your hands, detach the black strip from the board without removing it.
      FixBot'a Sor
      Yorum Ekle
    9. HTC One Mini Battery Replacement: adım 14, 2 resimden 1. HTC One Mini Battery Replacement: adım 14, 2 resimden 2.
      • Detach carefully with your tweezers the volume buttons.
      • Detach the power button with your tweezers.
      FixBot'a Sor
      Yorum Ekle
    10. HTC One Mini Battery Replacement: adım 15, 3 resimden 1. HTC One Mini Battery Replacement: adım 15, 3 resimden 2. HTC One Mini Battery Replacement: adım 15, 3 resimden 3.
      • Identify the screw behind the cable.
      • Remove the screw using a Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    11. HTC One Mini Battery Replacement: adım 16, 2 resimden 1. HTC One Mini Battery Replacement: adım 16, 2 resimden 2.
      • Lift the motherboard, but don't try to remove it completely yet.
      • Handle the board only by the edges.
      FixBot'a Sor
      Yorum Ekle
    12. HTC One Mini Battery Replacement: adım 17, 3 resimden 1. HTC One Mini Battery Replacement: adım 17, 3 resimden 2. HTC One Mini Battery Replacement: adım 17, 3 resimden 3.
      • Using your tweezers, remove the black square located in the power button.
      • Remove the motherboard completely.
      FixBot'a Sor
      Yorum Ekle
    1. HTC One Mini Battery Replacement, Remove Lower Speaker: adım 18, 3 resimden 1. HTC One Mini Battery Replacement, Remove Lower Speaker: adım 18, 3 resimden 2. HTC One Mini Battery Replacement, Remove Lower Speaker: adım 18, 3 resimden 3.
      • Using the spudger, use force to detach and remove the speaker.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One Mini Battery Replacement: adım 19, 3 resimden 1. HTC One Mini Battery Replacement: adım 19, 3 resimden 2. HTC One Mini Battery Replacement: adım 19, 3 resimden 3.
      • Use a wide pry tool or credit card to gently pry the battery up and out of the phone.
      • Do not puncture or deform the battery in any way, or a dangerous fire or explosion may result.
      FixBot'a Sor
      Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Daniela Delgado
577 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Brown Fall 2014 USF Tampa, Team 3-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G4
3 Üyeler
35 adet Kılavuz yazıldı
6Kılavuz Yorumları
I accidently teared the power button cable a little.
I guess i will have to buy a new one, but i wonder is it soldered ?
I don't think so but i'm not sure.
Is there a nother way to power it on for now ?
rssd - Yanıt Paylaş
Please tell me,can i use battery from htc one mini 2 in htc one mini? I just want increase the battery capacity from 1800 to 2100.thanks for the answer
marat ospanov - Yanıt Paylaş
I completed the steps as described and have an issue with my display now. I tried to start the device before pressing it in the back cover to check whether it works or not. It seems to work, but the display don't. Which cable is that of the display and / or what could have gone wrong? Thx!
tobiasemmert - Yanıt Paylaş
I changed the battery, but now, the sound doesn't works. The microphone and the diffuser do not work. What can I do ?
niculoiualina - Yanıt Paylaş
Just ruined my phone thanks to the worst ever tutorial i’ve ever seen.
Crispy K - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 40
Her zaman: 46,462
