Ana içeriğe geç
HTC One Mini LCD Display Replacement
Neye ihtiyacın var
    1. HTC One Mini LCD Display Replacement, iOpener Heating: adım 1, 1 resimden 1.
      • Use the iOpener to melt the glue off of the top and bottom speaker grills.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One Mini LCD Display Replacement, Remove Speaker Grills: adım 2, 1 resimden 1.
      • Use the blue plastic opening tool to pry and remove the bottom speaker grill.
      FixBot'a Sor
      Yorum Ekle
    3. HTC One Mini LCD Display Replacement, Remove Screw: adım 3, 3 resimden 1. HTC One Mini LCD Display Replacement, Remove Screw: adım 3, 3 resimden 2. HTC One Mini LCD Display Replacement, Remove Screw: adım 3, 3 resimden 3.
      • Remove the screw under speaker grill using a T6 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. HTC One Mini LCD Display Replacement: adım 4, 3 resimden 1. HTC One Mini LCD Display Replacement: adım 4, 3 resimden 2. HTC One Mini LCD Display Replacement: adım 4, 3 resimden 3.
      • Wedge the plastic opening tool between the screen and the edge of the case.
      • Use force to pry and separate the rear panel.
      FixBot'a Sor
      Yorum Ekle
    5. HTC One Mini LCD Display Replacement, Separate Rear Case: adım 5, 2 resimden 1. HTC One Mini LCD Display Replacement, Separate Rear Case: adım 5, 2 resimden 2.
      • Separate the rear panel from the phone.
      FixBot'a Sor
      Yorum Ekle
    6. HTC One Mini LCD Display Replacement: adım 6, 2 resimden 1. HTC One Mini LCD Display Replacement: adım 6, 2 resimden 2.
      • Using the plastic opening tool, pry on the screen to separate it from the adhesive holding it.
      FixBot'a Sor
      Yorum Ekle
    7. HTC One Mini LCD Display Replacement, Separate LCD Screen: adım 7, 2 resimden 1. HTC One Mini LCD Display Replacement, Separate LCD Screen: adım 7, 2 resimden 2.
      • After you have used the opening tool to pry, use some force to separate the LCD screen from the glue.
      FixBot'a Sor
      Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Chris Jose
735 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Brown Fall 2014 USF Tampa, Team 3-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G4
3 Üyeler
35 adet Kılavuz yazıldı
2Kılavuz Yorumları
I have bought a new lcd digitizer for an htc m8 mini 2….I've assemble it and when i have turned the power on all i got was a light coming on… no displays on the screen…what could be the issue??
Ramon Alex Headley - Yanıt Paylaş
Is it easier to fix if only the screen glass is broken and not the LCD?
myshepherd - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 49,051
