Giriş
Follow the instructions in this guide to remove your HTC One Mini's rear case and detach your motherboard from the rest of the phone so that it may be replaced.
Neye ihtiyacın var
Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
Remove the lower speaker cover.
Bu adımda kullanılan alet:Tweezers$4.99
Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
