Ana içeriğe geç
HTC One Mini Rear Case Replacement
Neye ihtiyacın var
    1. HTC One Mini Rear Case Replacement, iOpener Heating: adım 1, 1 resimden 1.
      • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One Mini Rear Case Replacement, Remove Speaker Grills: adım 2, 1 resimden 1.
      • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
      • Remove the lower speaker cover.
      FixBot'a Sor
      Yorum Ekle
    3. HTC One Mini Rear Case Replacement, Remove Screw: adım 3, 3 resimden 1. HTC One Mini Rear Case Replacement, Remove Screw: adım 3, 3 resimden 2. HTC One Mini Rear Case Replacement, Remove Screw: adım 3, 3 resimden 3.
      • Remove the screw under the speaker cover using a T6 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. HTC One Mini Rear Case Replacement: adım 4, 3 resimden 1. HTC One Mini Rear Case Replacement: adım 4, 3 resimden 2. HTC One Mini Rear Case Replacement: adım 4, 3 resimden 3.
      • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
      • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
      FixBot'a Sor
      Yorum Ekle
    5. HTC One Mini Rear Case Replacement, Separate Rear Case: adım 5, 2 resimden 1. HTC One Mini Rear Case Replacement, Separate Rear Case: adım 5, 2 resimden 2.
      • Remove the rear case from the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chris Jose
735 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Brown Fall 2014 USF Tampa, Team 3-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G4
3 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 7,229
