Giriş
This repair guide will show you step-by-step how to take off the rear casing of your HTC One Mini and safely remove your current rear camera.
Neye ihtiyacın var
Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
Remove the lower speaker cover.
Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
Remove the motherboard and place it so that the rear camera is face down.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
where can I get the rear camera? what is te number part. tks
