Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Use the plastic opening tool to loosen the adhesive from the crease surrounding the screen.
    • Use the plastic opening tool to loosen the adhesive from the crease surrounding the screen.
    • The volume button is a good place to begin, it should come right out as you pry.
  2. Wedge the plastic opening tool into the crack around the screen, on only the top, left and right sides.
    • Wedge the plastic opening tool into the crack around the screen, on only the top, left and right sides.
    • Applying heat with the iOpener or a heat gun can speed this process.
  3. Once the screen has been loosened on the top, left and right edges, lift the screen. It will remain attached at the bottom on a hinge.
    • Once the screen has been loosened on the top, left and right edges, lift the screen. It will remain attached at the bottom on a hinge.
    • The screen will remain attached to this hinge until the final step.
  4. Carefully remove the volume button. Loosen the back panel of the phone with the plastic opening tool. Begin loosening and prying in the space where the battery was.
    • Carefully remove the volume button. Loosen the back panel of the phone with the plastic opening tool. Begin loosening and prying in the space where the battery was.
  5. Once the crease has been loosened all around, pry the back panel open and lift until it can be removed.
    • Once the crease has been loosened all around, pry the back panel open and lift until it can be removed.
  6. Remove tape to expose #000 screws, remove all screws.
    • Remove tape to expose #000 screws, remove all screws.
    • Use the #000 bit screwdriver
  7. Reach beneath the motherboard with the tweezers, grip it and lift.
    • Reach beneath the motherboard with the tweezers, grip it and lift.
    • Lift with care, the motherboard is not completely disconnected yet.
    • Remove the tape connecting the motherboard to the phone and gently lift it out.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Meghan
458 İtibar
1 Kılavuz yazıldı
Takım
USF Tampa, Team 12-1, Blackwell Fall 2014 USF Tampa, Team 12-1, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S12G1
4 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
Where can I buy a motherboard to do the replacement?
Askateth - Yanıt
Will changing the motherboard fix the pink tint in my camera?
mmm50592 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 14,380
