Giriş
1. adıma git ↓If your front camera isn't working as needed, just replace it! This guide will teach you how.
Neye ihtiyacın var
Aletler
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Using the pointed end of a spudger, lift the battery cable and release the connector.
Bu adımda kullanılan alet:Tweezers$4.99
Similar to step 18, remove the polyimide tape with tweezers.
