Ana içeriğe geç
HTC One Speaker Replacement
Neye ihtiyacın var
  1. HTC One Speaker Replacement, Speaker: adım 1, 3 resimden 1. HTC One Speaker Replacement, Speaker: adım 1, 3 resimden 2. HTC One Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. HTC One Speaker Replacement: adım 2, 1 resimden 1.
    • Pry the back loose and lift. The back panel will come off with time.
  3. HTC One Speaker Replacement: adım 3, 1 resimden 1.
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. HTC One Speaker Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  5. HTC One Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  6. HTC One Speaker Replacement: adım 6, 2 resimden 1. HTC One Speaker Replacement: adım 6, 2 resimden 2.
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  7. HTC One Speaker Replacement: adım 7, 2 resimden 1. HTC One Speaker Replacement: adım 7, 2 resimden 2.
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  8. HTC One Speaker Replacement: adım 8, 3 resimden 1. HTC One Speaker Replacement: adım 8, 3 resimden 2. HTC One Speaker Replacement: adım 8, 3 resimden 3.
    • Completely remove the motherboard.
  9. HTC One Speaker Replacement: adım 9, 2 resimden 1. HTC One Speaker Replacement: adım 9, 2 resimden 2.
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Alex
664 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 12-1, Blackwell Fall 2014 USF Tampa, Team 12-1, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S12G1
4 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
Ok I will good
Raguraman - Yanıt
Where to buy speaker???
bharatdshmkh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 19,455
