Ana içeriğe geç
HTC One V Camera Replacement
Neye ihtiyacın var
    1. HTC One V Camera Replacement, Disassembling HTC ONE V Bottom Assembly: adım 1, 3 resimden 1. HTC One V Camera Replacement, Disassembling HTC ONE V Bottom Assembly: adım 1, 3 resimden 2. HTC One V Camera Replacement, Disassembling HTC ONE V Bottom Assembly: adım 1, 3 resimden 3.
      • Power off your device.
      • Remove the bottom cover by sliding it off.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One V Camera Replacement: adım 2, 1 resimden 1.
      • Remove the SIM card.
      • Remove the four screws securing the bottom casing.
      • Two 3.0 mm Phillips #0 screws in the top left and right corners.
      • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
      FixBot'a Sor
      Yorum Ekle
    3. HTC One V Camera Replacement: adım 3, 2 resimden 1. HTC One V Camera Replacement: adım 3, 2 resimden 2.
      • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. HTC One V Camera Replacement: adım 4, 3 resimden 1. HTC One V Camera Replacement: adım 4, 3 resimden 2. HTC One V Camera Replacement: adım 4, 3 resimden 3.
      • Use a plastic opening tool to pry open the bottom casing.
      • Remove the bottom casing by pulling it towards you.
      FixBot'a Sor
      Yorum Ekle
    1. HTC One V Camera Replacement, Disassembling HTC One V Back Case: adım 5, 3 resimden 1. HTC One V Camera Replacement, Disassembling HTC One V Back Case: adım 5, 3 resimden 2. HTC One V Camera Replacement, Disassembling HTC One V Back Case: adım 5, 3 resimden 3.
      • Use the plastic opening tool to pry open the rear camera panel.
      • Remove both screws that are securing the back case.
      • One 4.0 mm Phillips #0 screw.
      • One 3.0 mm Phillips #0 screw.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One V Camera Replacement: adım 6, 3 resimden 1. HTC One V Camera Replacement: adım 6, 3 resimden 2. HTC One V Camera Replacement: adım 6, 3 resimden 3.
      • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
      • Pry from right to left to avoid potential damages to the ribbon.
      FixBot'a Sor
      Yorum Ekle
    3. HTC One V Camera Replacement: adım 7, 3 resimden 1. HTC One V Camera Replacement: adım 7, 3 resimden 2. HTC One V Camera Replacement: adım 7, 3 resimden 3.
      • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
      • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
      FixBot'a Sor
      Yorum Ekle
    1. HTC One V Camera Replacement, Battery: adım 8, 1 resimden 1.
      • Pry up the battery with the flat end of the spudger.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One V Camera Replacement: adım 9, 3 resimden 1. HTC One V Camera Replacement: adım 9, 3 resimden 2. HTC One V Camera Replacement: adım 9, 3 resimden 3.
      • Gently lift up the battery away from the edge of its housing.
      • Use the point end of the spudger to push the connection out of its housing.
      FixBot'a Sor
      Yorum Ekle
    1. HTC One V Camera Replacement, Camera Lens: adım 10, 3 resimden 1. HTC One V Camera Replacement, Camera Lens: adım 10, 3 resimden 2. HTC One V Camera Replacement, Camera Lens: adım 10, 3 resimden 3.
      • Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One V Camera Replacement: adım 11, 1 resimden 1.
      • Pry off the camera lens using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. HTC One V Camera Replacement, Vibrator: adım 12, 2 resimden 1. HTC One V Camera Replacement, Vibrator: adım 12, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Pry the vibrator out of the housing with a spudger.
      • Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. HTC One V Camera Replacement, Motherboard: adım 13, 3 resimden 1. HTC One V Camera Replacement, Motherboard: adım 13, 3 resimden 2. HTC One V Camera Replacement, Motherboard: adım 13, 3 resimden 3.
      • Using the spudger lift the tabs on the highlighted, red and orange, ribbon connectors. Gently pull out the ribbons from their connectors.
      • Remove the 3.0 mm Phillips #0 screw.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One V Camera Replacement: adım 14, 3 resimden 1. HTC One V Camera Replacement: adım 14, 3 resimden 2. HTC One V Camera Replacement: adım 14, 3 resimden 3.
      • Using tweezers, pull back on the tape located on the bottom corners of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. HTC One V Camera Replacement: adım 15, 2 resimden 1. HTC One V Camera Replacement: adım 15, 2 resimden 2.
      • Use the spudger to push back the latch holding on the motherboard. While the latch is pushed back use the plastic opening tool to pry up the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. HTC One V Camera Replacement: adım 16, 1 resimden 1.
      • Place your phone on its side so that you can gently pull up on the motherboard to expose its last connector.
      • Using the flat end of the spudger, pop of the connector.
      FixBot'a Sor
      Yorum Ekle
    1. HTC One V Camera Replacement, Camera: adım 17, 2 resimden 1. HTC One V Camera Replacement, Camera: adım 17, 2 resimden 2.
      • Flip motherboard over so the backside is up.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One V Camera Replacement: adım 18, 2 resimden 1. HTC One V Camera Replacement: adım 18, 2 resimden 2.
      • Pull the camera back using the tweezers, and hold it.
      • Use the spudger to unlock the camera's ribbon from its connector.
      • Using the tweezers, pull up on the ribbon and release the camera form the motherboard.
      • The ribbon is connected to the back of the LCD display by tape. Slowly pull the ribbon back and the tape will follow.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Michael Lucido
852 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Blackwell Winter 2015 USF Tampa, Team 1-3, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S1G3
4 Üyeler
56 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 1,281
