Ana içeriğe geç
HTC One V Loudspeaker Replacement
Neye ihtiyacın var
  1. HTC One V Loudspeaker Replacement, Disassembling HTC ONE V Bottom Assembly: adım 1, 3 resimden 1. HTC One V Loudspeaker Replacement, Disassembling HTC ONE V Bottom Assembly: adım 1, 3 resimden 2. HTC One V Loudspeaker Replacement, Disassembling HTC ONE V Bottom Assembly: adım 1, 3 resimden 3.
    • Power off your device.
    • Remove the bottom cover by sliding it off.
  2. HTC One V Loudspeaker Replacement: adım 2, 1 resimden 1.
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
  3. HTC One V Loudspeaker Replacement: adım 3, 2 resimden 1. HTC One V Loudspeaker Replacement: adım 3, 2 resimden 2.
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
  4. HTC One V Loudspeaker Replacement: adım 4, 3 resimden 1. HTC One V Loudspeaker Replacement: adım 4, 3 resimden 2. HTC One V Loudspeaker Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
  5. HTC One V Loudspeaker Replacement, Loudspeaker: adım 5, 2 resimden 1. HTC One V Loudspeaker Replacement, Loudspeaker: adım 5, 2 resimden 2.
    • Using a plastic opening tool, peel off the speaker cover.
  6. HTC One V Loudspeaker Replacement: adım 6, 1 resimden 1.
    • Use the spudger to push the speaker out of its casing.
Sonuç
abebe alemu
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Blackwell Winter 2015 USF Tampa, Team 1-3, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S1G3
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 453
