Ana içeriğe geç
HTC One X Antenna Replacement
Neye ihtiyacın var
  1. HTC One X Antenna Replacement, Squeeze Test: adım 1, 1 resimden 1.
    • Before replacement of the antenna, carry out the squeeze test.
    • Gently squeeze your device between the camera lens and the volume button. This should temporarily reconnect the antenna if it's loose.
    • If the squeeze test doesn't reconnect your wi-fi/bluetooth then move to step 2
    FixBot'a Sor
    Yorum Ekle
  2. HTC One X Antenna Replacement, Remove SIM card slot: adım 2, 1 resimden 1.
    • Insert a safety pin, or other small object into the narrow aperture next to the Sim Card Slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
    FixBot'a Sor
    Yorum Ekle
  3. HTC One X Antenna Replacement, Remove front panel: adım 3, 2 resimden 1. HTC One X Antenna Replacement, Remove front panel: adım 3, 2 resimden 2.
    • Use a plastic opening tool, and carefully insert it between the display and rear panel. Separate the two parts.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage or bodily harm.
    • Set aside the rear panel for now
    FixBot'a Sor
    Yorum Ekle
  4. HTC One X Antenna Replacement, Replace antenna: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Once the rear panel is separated from the front panel, remove the antenna using tweezers.
    • The antenna is located on the right hand side of the front panel as indicated in the image.
    • Replace and reconnect the new antenna in the same position as the faulty one you just removed. Remember to place it underneath the metal supports on the board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Blain Abebe
769 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-3, Brown Fall 2014 USF Tampa, Team 4-3, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G3
3 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 29
Her zaman: 9,814
