Ana içeriğe geç
HTC One X Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. HTC One X Battery Replacement, Battery: adım 1, 3 resimden 1. HTC One X Battery Replacement, Battery: adım 1, 3 resimden 2. HTC One X Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Switch the phone off.
    • Remove the SIM tray.
    • The back cover is stuck to the phone with adhesive tape.
    • It's helpful to use heat to loosen the adhesive, making removal much easier.
  2. HTC One X Battery Replacement: adım 2, 3 resimden 1. HTC One X Battery Replacement: adım 2, 3 resimden 2. HTC One X Battery Replacement: adım 2, 3 resimden 3.
    • Start opening from the bottom side.
    • For separating the back cover, use only plastic tools.
  3. HTC One X Battery Replacement: adım 3, 2 resimden 1. HTC One X Battery Replacement: adım 3, 2 resimden 2.
    • Remove the display assembly from the body of the phone.
  4. HTC One X Battery Replacement: adım 4, 2 resimden 1. HTC One X Battery Replacement: adım 4, 2 resimden 2.
    • Remove the seven Philips #0 screws at the top of the panel:
    • Two 2.05 mm screws
    • Three 2.44 mm screws
    • Two 3.35 mm screws
    • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
  5. HTC One X Battery Replacement: adım 5, 3 resimden 1. HTC One X Battery Replacement: adım 5, 3 resimden 2. HTC One X Battery Replacement: adım 5, 3 resimden 3.
    • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
    • Carefully insert a plastic tool under the battery to pry it up from the adhesive. Avoid bending the battery.
    • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
    • Now you can separate the Dock flex cable.
  6. HTC One X Battery Replacement: adım 6, 2 resimden 1. HTC One X Battery Replacement: adım 6, 2 resimden 2.
    • A piece of copper tape covers the battery and an EMI shield on the motherboard.
    • Carefully pry the EMI shield up at the top of the phone and toward the battery.
    • Carefully peel the copper tape off of the battery and save it to transfer to the new battery.
  7. HTC One X Battery Replacement: adım 7, 3 resimden 1. HTC One X Battery Replacement: adım 7, 3 resimden 2. HTC One X Battery Replacement: adım 7, 3 resimden 3.
    • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
    • Disconnect the Power On button flex cable at the upper side of the phone
    • Now the mainboard and the battery are free.
    • Disconnect the battery and you are ready to install the new one.
  8. HTC One X Battery Replacement: adım 8, 2 resimden 1. HTC One X Battery Replacement: adım 8, 2 resimden 2.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
ZFix
196.103 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
331 Üyeler
1.458 adet Kılavuz yazıldı
2Kılavuz Yorumları
Perfecto! Me vino genial el tutorial y es perfecto, mejor que otros.
hepugh - Yanıt
Went very well. I had a dead HTC One X that I replaced 4 years ago. I came across it a few weeks ago and thought to give a new battery a try, to see if I can get the photos off it. It did not charge (no lights) and did not turn on anymore. I ordered a battery from AliExpress and it came in today. Followed this guide, and yes, it turned on again! And charging is also working properly now. So I am happy, now I can get my photos and use the phone as a Android 4.2 testing target for the apps I develop. Wonderful.
Peterdk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 87
Her zaman: 47,255
