Ana içeriğe geç
HTC One X LCD Display & Touch Screen Glass Digitizer Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: adım 1, 3 resimden 1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: adım 1, 3 resimden 2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: adım 1, 3 resimden 3.
    • Switch-off the phone (if you can).
    • Remove the SIM tray.
    • The back cover is sticked to the phone with adhesive tape. Is good to use some hot air to do removing of the back cover easier.
  2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 2, 3 resimden 1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 2, 3 resimden 2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 2, 3 resimden 3.
    • Start opening from the bottom side.
    • For separating the back cover, use only plastic tools.
  3. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 3, 3 resimden 1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 3, 3 resimden 2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 3, 3 resimden 3.
    • The mother board is held by 6x Philips screws.
  4. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 4, 3 resimden 1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 4, 3 resimden 2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 4, 3 resimden 3.
    • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
    • Use a plastic tool to unstick the battery.
    • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
    • Now you can separate the Dock flex cable.
  5. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 5, 3 resimden 1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 5, 3 resimden 2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 5, 3 resimden 3.
    • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
    • Disconnect the Power On button flex cable at the upper side of the phone
    • Now the mainboard and the battery are free.
    • Disconnect the battery from the mainboard.
  6. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 6, 3 resimden 1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 6, 3 resimden 2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 6, 3 resimden 3.
    • At the beginning you can use a cutter to make a room for the plastic tool.
    • During the procedure of the separating the LCD Display & Touchscreen from the frame, you can use again hot air. This will make separating more easy.
  7. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 7, 3 resimden 1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 7, 3 resimden 2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 7, 3 resimden 3.
    • The original adhesive tape is left on the frame, but I prefer to put new. I put it onto the original.
    • Gently assemble the screen to the frame.
  8. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: adım 8, 1 resimden 1.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
ZFix
196.809 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
333 Üyeler
1.479 adet Kılavuz yazıldı
1Rehber Yorum
i need touch panel do you have available
osama siddique - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 50
Her zaman: 38,861
