Ana içeriğe geç
HTC One X Plus Antenna Replacement
Neye ihtiyacın var
  1. HTC One X Plus Antenna Replacement, Antenna: adım 1, 1 resimden 1.
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro-SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
    FixBot'a Sor
    Yorum Ekle
  2. HTC One X Plus Antenna Replacement: adım 2, 3 resimden 1. HTC One X Plus Antenna Replacement: adım 2, 3 resimden 2. HTC One X Plus Antenna Replacement: adım 2, 3 resimden 3.
    • Using the plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
    FixBot'a Sor
    Yorum Ekle
  3. HTC One X Plus Antenna Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Now that the rear panel has been removed, use the metal tweezers to carefully remove the antenna.
    • The antenna is the loose black wire located to the right of the battery.
    • Using the metal tweezers, connect and install your new antenna, securing the antenna beneath the metal supports.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jason Melo
483 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G3
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 955
