Ana içeriğe geç
HTC One X Plus Battery Replacement
Neye ihtiyacın var
  1. HTC One X Plus Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
    FixBot'a Sor
    Yorum Ekle
  2. HTC One X Plus Battery Replacement: adım 2, 3 resimden 1. HTC One X Plus Battery Replacement: adım 2, 3 resimden 2. HTC One X Plus Battery Replacement: adım 2, 3 resimden 3.
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
    FixBot'a Sor
    Yorum Ekle
  3. HTC One X Plus Battery Replacement: adım 3, 3 resimden 1. HTC One X Plus Battery Replacement: adım 3, 3 resimden 2. HTC One X Plus Battery Replacement: adım 3, 3 resimden 3.
    • Remove the five 2.4mm screws using a Phillips head screw driver and then remove the plastic cover.
    FixBot'a Sor
    Yorum Ekle
  4. HTC One X Plus Battery Replacement: adım 4, 3 resimden 1. HTC One X Plus Battery Replacement: adım 4, 3 resimden 2. HTC One X Plus Battery Replacement: adım 4, 3 resimden 3.
    • Remove the two 3.4 mm JIS #000 screws from the PCB board.
    • Remove the PCB board and antenna.
    FixBot'a Sor
    Yorum Ekle
  5. HTC One X Plus Battery Replacement: adım 5, 2 resimden 1. HTC One X Plus Battery Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to disconnect the power button flex cable.
    • Disconnect the touch screen flex cable
    FixBot'a Sor
    Yorum Ekle
  6. HTC One X Plus Battery Replacement: adım 6, 3 resimden 1. HTC One X Plus Battery Replacement: adım 6, 3 resimden 2. HTC One X Plus Battery Replacement: adım 6, 3 resimden 3.
    • Disconnect the battery from the logic board by detaching the six pin connector.
    • Remove the battery by pulling upwards.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Vitterio Crisp
119 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G3
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 29
Her zaman: 4,432
