Ana içeriğe geç
HTC One X Plus Screen Replacement
Neye ihtiyacın var
  1. HTC One X Plus Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal in the hole next to the micro sim card holder to remove it.
    • The sim card slot is located on the top edge of the device.
  2. HTC One X Plus Screen Replacement: adım 2, 3 resimden 1. HTC One X Plus Screen Replacement: adım 2, 3 resimden 2. HTC One X Plus Screen Replacement: adım 2, 3 resimden 3.
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Screen Replacement: adım 3, 3 resimden 1. HTC One X Plus Screen Replacement: adım 3, 3 resimden 2. HTC One X Plus Screen Replacement: adım 3, 3 resimden 3.
    • Remove the five 2.4 mm screws using a Phillips #000 screwdriver.
    • Remove the plastic cover.
  4. HTC One X Plus Screen Replacement: adım 4, 3 resimden 1. HTC One X Plus Screen Replacement: adım 4, 3 resimden 2. HTC One X Plus Screen Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the two 3.4 mm screws.
    • Remove the PCB board and antenna.
  5. HTC One X Plus Screen Replacement: adım 5, 2 resimden 1. HTC One X Plus Screen Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to disconnect the power button flex cable.
  6. HTC One X Plus Screen Replacement: adım 6, 3 resimden 1. HTC One X Plus Screen Replacement: adım 6, 3 resimden 2. HTC One X Plus Screen Replacement: adım 6, 3 resimden 3.
    • Disconnect the battery's six pin connector from the motherboard.
    • Remove the battery by pulling it upwards.
  7. HTC One X Plus Screen Replacement: adım 7, 1 resimden 1.
    • Disconnect the screen from the digitizer.
    • Use a plastic opening tool to gently disconnect the screen from the digitizer.
    • You may have to use heat to loosen adhesive securing the screen.
Sonuç
Jason Melo
483 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G3
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Man, this did nothing but break my International One X+. There were so many instructions missing.
Garrett Reyman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 2,002
