Ana içeriğe geç
HTC One X Plus Top Speaker Replacement
Neye ihtiyacın var
  1. HTC One X Plus Top Speaker Replacement, Top Speaker: adım 1, 1 resimden 1.
    • Hold down the power button to turn off your device.
    • Insert a pin, paper clip, or another similar object into the hole next to the micro sim card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Top Speaker Replacement: adım 2, 3 resimden 1. HTC One X Plus Top Speaker Replacement: adım 2, 3 resimden 2. HTC One X Plus Top Speaker Replacement: adım 2, 3 resimden 3.
    • Using plastic opening tools, pry open the bottom of the device.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Top Speaker Replacement: adım 3, 3 resimden 1. HTC One X Plus Top Speaker Replacement: adım 3, 3 resimden 2. HTC One X Plus Top Speaker Replacement: adım 3, 3 resimden 3.
    • Remove the five 2.4mm screws located around the camera using a Philips head screwdriver to remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Top Speaker Replacement: adım 4, 3 resimden 1. HTC One X Plus Top Speaker Replacement: adım 4, 3 resimden 2. HTC One X Plus Top Speaker Replacement: adım 4, 3 resimden 3.
    • Use the J000 Philips screwdriver to remove the screws and remove the PCB board and antenna.
    • These are two 3.4mm Philips head screws found in the lower right corner of the phone.
  5. HTC One X Plus Top Speaker Replacement: adım 5, 2 resimden 1. HTC One X Plus Top Speaker Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Pull out the power button flex cable using tweezers to disconnect from the phone.
    • Use the tweezers to then disconnect the touch screen flex cable.
  6. HTC One X Plus Top Speaker Replacement: adım 6, 3 resimden 1. HTC One X Plus Top Speaker Replacement: adım 6, 3 resimden 2. HTC One X Plus Top Speaker Replacement: adım 6, 3 resimden 3.
    • Remove the battery connections to the logic board.
    • This is the six pin connector seen in the red box.
    • Pull the battery away to remove from the back of the screen.
  7. HTC One X Plus Top Speaker Replacement: adım 7, 2 resimden 1. HTC One X Plus Top Speaker Replacement: adım 7, 2 resimden 2.
    • CAUTION: carefully remove the top speaker from the phone using tweezers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jason Melo
483 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 20
Her zaman: 480
