Ana içeriğe geç
HTC One X SIM Card Tray Replacement
Neye ihtiyacın var
    1. HTC One X SIM Card Tray Replacement, SIM Card Tray: adım 1, 1 resimden 1.
      • Insert a safety pin or other small object in the small opening next to the SIM card slot to remove the SIM card.
      • The Sim Card Slot is located at the top of the rear panel.
      FixBot'a Sor
      Yorum Ekle
    2. HTC One X SIM Card Tray Replacement, Repair SIM card tray: adım 2, 1 resimden 1.
      • Cut a piece of tape/ paper approximately the size of your Sim Card and secure it to the back side of the Sim. Be sure to trim any excess.
      • It's important that you place the tape on the back side of the Sim Card as it will block the communication with the device if placed on the front side
      • Slowly slide the Sim Card tray back into the device. It should be a smooth transition, don't force the tray in.
      • If the tray is still loose you can keep adding tape/paper until it's no longer loose.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Blain Abebe
769 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-3, Brown Fall 2014 USF Tampa, Team 4-3, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G3
3 Üyeler
84 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 7,550
