Ana içeriğe geç
Giriş
Internal components of a cell phone device are protected by a plastic frame (i.e. motherboard, keyboard, screen, etc.)
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the phone over to have the rear cover facing up.
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. Slide the cover up, towards the top of phone, to unlock the battery cover. Lift the cover off phone and remove it.
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Use your finger to push the top of the battery downwards and lift the battery out of the phone. Use your finger to push the top of the battery downwards and lift the battery out of the phone. Use your finger to push the top of the battery downwards and lift the battery out of the phone.
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  5. Remove the six Torx #5 screws that are securing the rear frame. Remove the six Torx #5 screws that are securing the rear frame. Remove the six Torx #5 screws that are securing the rear frame.
    • Remove the six Torx #5 screws that are securing the rear frame.
  6. Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool. A plastic card can be used instead of the plastic opening tool. A plastic card can be used instead of the plastic opening tool.
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Marco Jokada
247 İtibar
6 adet Kılavuz yazıldı
Takım
CSU Los Angeles, Team 1-2, Nelson Spring 2011 CSU Los Angeles, Team 1-2, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G2
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,298
