Ana içeriğe geç
HTC Ozone Keyboard Replacement
Neye ihtiyacın var
    1. HTC Ozone Keyboard Replacement, Rear Battery Cover: adım 1, 1 resimden 1.
      • Flip the phone over to have the rear cover facing up.
      • The camera lens should be towards the top of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Ozone Keyboard Replacement: adım 2, 2 resimden 1. HTC Ozone Keyboard Replacement: adım 2, 2 resimden 2.
      • Slide the cover up, towards the top of phone, to unlock the battery cover.
      • Lift the cover off phone and remove it.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Ozone Keyboard Replacement, Battery: adım 3, 3 resimden 1. HTC Ozone Keyboard Replacement, Battery: adım 3, 3 resimden 2. HTC Ozone Keyboard Replacement, Battery: adım 3, 3 resimden 3.
      • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Ozone Keyboard Replacement, Frame: adım 4, 2 resimden 1. HTC Ozone Keyboard Replacement, Frame: adım 4, 2 resimden 2.
      • Remove the six Torx #5 screws that are securing the rear frame.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Ozone Keyboard Replacement: adım 5, 3 resimden 1. HTC Ozone Keyboard Replacement: adım 5, 3 resimden 2. HTC Ozone Keyboard Replacement: adım 5, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
      • A plastic card can be used instead of the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Ozone Keyboard Replacement, Motherboard: adım 6, 2 resimden 1. HTC Ozone Keyboard Replacement, Motherboard: adım 6, 2 resimden 2.
      • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Ozone Keyboard Replacement: adım 7, 2 resimden 1. HTC Ozone Keyboard Replacement: adım 7, 2 resimden 2.
      • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
      • Be careful not to break the ribbon cable when prying away the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Ozone Keyboard Replacement: adım 8, 3 resimden 1. HTC Ozone Keyboard Replacement: adım 8, 3 resimden 2. HTC Ozone Keyboard Replacement: adım 8, 3 resimden 3.
      • Remove the plastic cover from the LCD display and the motherboard.
      • The Motherboard and the LCD are still attached together.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Ozone Keyboard Replacement, LCD Display: adım 9, 2 resimden 1. HTC Ozone Keyboard Replacement, LCD Display: adım 9, 2 resimden 2.
      • Remove the gray tape securing the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Ozone Keyboard Replacement: adım 10, 1 resimden 1.
      • Remove the yellow tape securing the connector lock.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Ozone Keyboard Replacement: adım 11, 2 resimden 1. HTC Ozone Keyboard Replacement: adım 11, 2 resimden 2.
      • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Ozone Keyboard Replacement: adım 12, 1 resimden 1.
      • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Ozone Keyboard Replacement: adım 13, 1 resimden 1.
      • Lift the Motherboard away from the LCD display.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Ozone Keyboard Replacement, Keyboard: adım 14, 2 resimden 1. HTC Ozone Keyboard Replacement, Keyboard: adım 14, 2 resimden 2.
      • Lift off main keyboard from front plastic case using plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Ozone Keyboard Replacement: adım 15, 2 resimden 1. HTC Ozone Keyboard Replacement: adım 15, 2 resimden 2.
      • Remove four Phillips #00 screws securing function keys.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Ozone Keyboard Replacement: adım 16, 2 resimden 1. HTC Ozone Keyboard Replacement: adım 16, 2 resimden 2.
      • Pop keys out by pushing keys from back of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Marco Jokada
247 İtibar
6 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 1-2, Nelson Spring 2011 CSU Los Angeles, Team 1-2, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G2
5 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 2,083
