Ana içeriğe geç
HTC Ozone LCD Display Replacement
Neye ihtiyacın var
  1. HTC Ozone LCD Display Replacement, Rear Battery Cover: adım 1, 1 resimden 1.
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone LCD Display Replacement: adım 2, 2 resimden 1. HTC Ozone LCD Display Replacement: adım 2, 2 resimden 2.
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone LCD Display Replacement, Battery: adım 3, 3 resimden 1. HTC Ozone LCD Display Replacement, Battery: adım 3, 3 resimden 2. HTC Ozone LCD Display Replacement, Battery: adım 3, 3 resimden 3.
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone LCD Display Replacement, Frame: adım 4, 3 resimden 1. HTC Ozone LCD Display Replacement, Frame: adım 4, 3 resimden 2. HTC Ozone LCD Display Replacement, Frame: adım 4, 3 resimden 3.
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone LCD Display Replacement: adım 5, 3 resimden 1. HTC Ozone LCD Display Replacement: adım 5, 3 resimden 2. HTC Ozone LCD Display Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone LCD Display Replacement, Motherboard: adım 6, 2 resimden 1. HTC Ozone LCD Display Replacement, Motherboard: adım 6, 2 resimden 2.
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone LCD Display Replacement: adım 7, 2 resimden 1. HTC Ozone LCD Display Replacement: adım 7, 2 resimden 2.
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone LCD Display Replacement: adım 8, 3 resimden 1. HTC Ozone LCD Display Replacement: adım 8, 3 resimden 2. HTC Ozone LCD Display Replacement: adım 8, 3 resimden 3.
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
  9. HTC Ozone LCD Display Replacement, LCD Display: adım 9, 2 resimden 1. HTC Ozone LCD Display Replacement, LCD Display: adım 9, 2 resimden 2.
    • Remove the gray tape securing the ribbon cable.
  10. HTC Ozone LCD Display Replacement: adım 10, 1 resimden 1.
    • Remove the yellow tape securing the connector lock.
  11. HTC Ozone LCD Display Replacement: adım 11, 2 resimden 1. HTC Ozone LCD Display Replacement: adım 11, 2 resimden 2.
    • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
  12. HTC Ozone LCD Display Replacement: adım 12, 1 resimden 1.
    • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
  13. HTC Ozone LCD Display Replacement: adım 13, 1 resimden 1.
    • Lift the Motherboard away from the LCD display.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Marco Jokada
247 İtibar
6 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 1-2, Nelson Spring 2011 CSU Los Angeles, Team 1-2, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G2
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,108
