Ana içeriğe geç
HTC Ozone Motherboard Replacement
Neye ihtiyacın var
  1. HTC Ozone Motherboard Replacement, Rear Battery Cover: adım 1, 1 resimden 1.
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Motherboard Replacement: adım 2, 2 resimden 1. HTC Ozone Motherboard Replacement: adım 2, 2 resimden 2.
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Motherboard Replacement, Battery: adım 3, 3 resimden 1. HTC Ozone Motherboard Replacement, Battery: adım 3, 3 resimden 2. HTC Ozone Motherboard Replacement, Battery: adım 3, 3 resimden 3.
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Motherboard Replacement, Frame: adım 4, 3 resimden 1. HTC Ozone Motherboard Replacement, Frame: adım 4, 3 resimden 2. HTC Ozone Motherboard Replacement, Frame: adım 4, 3 resimden 3.
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Motherboard Replacement: adım 5, 3 resimden 1. HTC Ozone Motherboard Replacement: adım 5, 3 resimden 2. HTC Ozone Motherboard Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. HTC Ozone Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Motherboard Replacement: adım 7, 2 resimden 1. HTC Ozone Motherboard Replacement: adım 7, 2 resimden 2.
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Motherboard Replacement: adım 8, 3 resimden 1. HTC Ozone Motherboard Replacement: adım 8, 3 resimden 2. HTC Ozone Motherboard Replacement: adım 8, 3 resimden 3.
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Marco Jokada
247 İtibar
6 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 1-2, Nelson Spring 2011 CSU Los Angeles, Team 1-2, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G2
5 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Where can I buy/find/get this motherboard? I have been looking for one for over a year now, thanks
Walt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,551
