Ana içeriğe geç
HTC Radar 4G Touch Digitizer Replacement
Neye ihtiyacın var
  1. HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: adım 1, 2 resimden 1. HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: adım 1, 2 resimden 2.
    • Slide the lower plastic panel off of the phone.
    • Remove the four screws from the white plastic cover of the phone using the T5 Torx screwdriver.
    • Remove the two black screws from the silver frame.
  2. HTC Radar 4G Touch Digitizer Replacement: adım 2, 1 resimden 1.
    • Remove the back cover by pressing on the back of the motherboard lightly and pulling the screen out carefully.
  3. HTC Radar 4G Touch Digitizer Replacement: adım 3, 1 resimden 1.
    • Remove the battery from the phone using a fingernail or an opening pick.
  4. HTC Radar 4G Touch Digitizer Replacement: adım 4, 1 resimden 1.
    • Remove the three screws using a screwdriver.
    • Remove the plastic frame.
  5. HTC Radar 4G Touch Digitizer Replacement: adım 5, 3 resimden 1. HTC Radar 4G Touch Digitizer Replacement: adım 5, 3 resimden 2. HTC Radar 4G Touch Digitizer Replacement: adım 5, 3 resimden 3.
    • Remove the upper board and motherboard from the phone using an opening tool.
    • The regular black nylon spudger should be used whenever possible, especially around motherboards.
  6. HTC Radar 4G Touch Digitizer Replacement: adım 6, 2 resimden 1. HTC Radar 4G Touch Digitizer Replacement: adım 6, 2 resimden 2.
    • Use your hands to remove the touch digitizer.
Sonuç
Kevin Guerra
101 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 12-5, Bennett Fall 2016 Texas Tech, Team 12-5, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S12G5
4 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 293
