Ana içeriğe geç
HTC Rezound Screen Replacement
Neye ihtiyacın var
  1. HTC Rezound Screen  Replacement, Battery: adım 1, 1 resimden 1.
    • Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Rezound Screen  Replacement: adım 2, 1 resimden 1.
    • Remove the red battery to replace.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Rezound Screen  Replacement, Screen: adım 3, 3 resimden 1. HTC Rezound Screen  Replacement, Screen: adım 3, 3 resimden 2. HTC Rezound Screen  Replacement, Screen: adım 3, 3 resimden 3.
    • Unscrew the six screws (Torx T4 size) shown in the photo.
    • Use the spudger to pry the casing off of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Rezound Screen  Replacement: adım 4, 2 resimden 1. HTC Rezound Screen  Replacement: adım 4, 2 resimden 2.
    • Gently remove the casing from the phone.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Rezound Screen  Replacement: adım 5, 1 resimden 1.
    • After the red casing is removed, the following components should be visible:
    • Main Camera
    • Headphone Jack
    • Vibration moter
    FixBot'a Sor
    Yorum Ekle
  6. HTC Rezound Screen  Replacement: adım 6, 2 resimden 1. HTC Rezound Screen  Replacement: adım 6, 2 resimden 2.
    • Remove the 2 screws (Torx T7 size), which are located on the upper left and lower right sides of the device.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Rezound Screen  Replacement: adım 7, 3 resimden 1. HTC Rezound Screen  Replacement: adım 7, 3 resimden 2. HTC Rezound Screen  Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers, flip the latch on the ribbon cables connecting the logic board to the screen and display. The screen and display for the HTC Rezound are likely fused to one another, so if you are replacing one you will likely need to replace both of them.
    • At this point all that's left is to insert the ribbon cables of your replacement into the same slot on the motherboard!
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bridgette Mellon
243 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 620
