Ana içeriğe geç
HTC Rhyme Battery Replacement
Neye ihtiyacın var
    1. HTC Rhyme Battery Replacement, Removing Back Cover: adım 1, 2 resimden 1. HTC Rhyme Battery Replacement, Removing Back Cover: adım 1, 2 resimden 2.
      • Slide the bottom back cover off of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Rhyme Battery Replacement: adım 2, 1 resimden 1.
      • Locate the four screws on the plastic cover and unscrew them.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Rhyme Battery Replacement: adım 3, 2 resimden 1. HTC Rhyme Battery Replacement: adım 3, 2 resimden 2.
      • Pry the sticker off from the sides.
      • You can use a metal spudger to do this.
      • Peel the sticker off with your hands.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Rhyme Battery Replacement, Remove the plastic cover: adım 4, 1 resimden 1.
      • Remove the plastic cover using your hands.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Rhyme Battery Replacement: adım 5, 1 resimden 1.
      • Remove the yellow ribbon.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Rhyme Battery Replacement: adım 6, 3 resimden 1. HTC Rhyme Battery Replacement: adım 6, 3 resimden 2. HTC Rhyme Battery Replacement: adım 6, 3 resimden 3.
      • Lift up the blue flaps underneath the battery.
      • Lift up the black flap at the top of the phone.
      • Lift up the black flap at the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    7. HTC Rhyme Battery Replacement, Remove the Motherboard: adım 7, 2 resimden 1. HTC Rhyme Battery Replacement, Remove the Motherboard: adım 7, 2 resimden 2.
      • Remove all 4 screws.
      • Carefully remove the motherboard with your hands.
      FixBot'a Sor
      Yorum Ekle
    8. HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: adım 8, 3 resimden 1. HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: adım 8, 3 resimden 2. HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: adım 8, 3 resimden 3.
      • Pry the back plastic casing off with your hands.
      FixBot'a Sor
      Yorum Ekle
    9. HTC Rhyme Battery Replacement, Removing the Battery: adım 9, 3 resimden 1. HTC Rhyme Battery Replacement, Removing the Battery: adım 9, 3 resimden 2. HTC Rhyme Battery Replacement, Removing the Battery: adım 9, 3 resimden 3.
      • Remove the screws.
      • Use a metal spudger to remove the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elizabeth Steiner
435 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-6, Leahy Fall 2014 USF Tampa, Team 9-6, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S9G6
3 Üyeler
35 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 36
Her zaman: 5,436
