Ana içeriğe geç
HTC Rhyme Battery Replacement
Neye ihtiyacın var
  1. HTC Rhyme Battery Replacement, Removing Back Cover: adım 1, 2 resimden 1. HTC Rhyme Battery Replacement, Removing Back Cover: adım 1, 2 resimden 2.
    • Slide the bottom back cover off of the phone.
  2. HTC Rhyme Battery Replacement: adım 2, 1 resimden 1.
    • Locate the four screws on the plastic cover and unscrew them.
  3. HTC Rhyme Battery Replacement: adım 3, 2 resimden 1. HTC Rhyme Battery Replacement: adım 3, 2 resimden 2.
    • Pry the sticker off from the sides.
    • You can use a metal spudger to do this.
    • Peel the sticker off with your hands.
  4. HTC Rhyme Battery Replacement, Remove the plastic cover: adım 4, 1 resimden 1.
    • Remove the plastic cover using your hands.
  5. HTC Rhyme Battery Replacement: adım 5, 1 resimden 1.
    • Remove the yellow ribbon.
  6. HTC Rhyme Battery Replacement: adım 6, 3 resimden 1. HTC Rhyme Battery Replacement: adım 6, 3 resimden 2. HTC Rhyme Battery Replacement: adım 6, 3 resimden 3.
    • Lift up the blue flaps underneath the battery.
    • Lift up the black flap at the top of the phone.
    • Lift up the black flap at the bottom of the phone.
  7. HTC Rhyme Battery Replacement, Remove the Motherboard: adım 7, 2 resimden 1. HTC Rhyme Battery Replacement, Remove the Motherboard: adım 7, 2 resimden 2.
    • Remove all 4 screws.
    • Carefully remove the motherboard with your hands.
  8. HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: adım 8, 3 resimden 1. HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: adım 8, 3 resimden 2. HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: adım 8, 3 resimden 3.
    • Pry the back plastic casing off with your hands.
  9. HTC Rhyme Battery Replacement, Removing the Battery: adım 9, 3 resimden 1. HTC Rhyme Battery Replacement, Removing the Battery: adım 9, 3 resimden 2. HTC Rhyme Battery Replacement, Removing the Battery: adım 9, 3 resimden 3.
    • Remove the screws.
    • Use a metal spudger to remove the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elizabeth Steiner
435 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-6, Leahy Fall 2014 USF Tampa, Team 9-6, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S9G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 5,040
