Ana içeriğe geç
HTC Rhyme Volume Button Replacement
Neye ihtiyacın var
  1. HTC Rhyme Volume Button  Replacement, Removing Back Cover: adım 1, 1 resimden 1.
    • Slide the bottom back cover off of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Rhyme Volume Button  Replacement: adım 2, 1 resimden 1.
    • Locate the four screws on the plastic cover and unscrew them.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Rhyme Volume Button  Replacement: adım 3, 1 resimden 1.
    • Pry the sticker off from the sides.
    • You can use a metal spudger to do this.
    • Peel the sticker off with your hands.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Rhyme Volume Button  Replacement, Remove the plastic cover: adım 4, 1 resimden 1.
    • Remove the plastic cover using your hands.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Rhyme Volume Button  Replacement: adım 5, 1 resimden 1.
    • Remove the yellow ribbon.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Rhyme Volume Button  Replacement: adım 6, 3 resimden 1. HTC Rhyme Volume Button  Replacement: adım 6, 3 resimden 2. HTC Rhyme Volume Button  Replacement: adım 6, 3 resimden 3.
    • Lift up the blue flaps underneath the battery.
    • Lift up the black flap at the top of the phone.
    • Lift up the black flap at the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Rhyme Volume Button  Replacement, Remove the Motherboard: adım 7, 2 resimden 1. HTC Rhyme Volume Button  Replacement, Remove the Motherboard: adım 7, 2 resimden 2.
    • Remove all 4 screws.
    • Carefully remove the motherboard with your hands.
    FixBot'a Sor
    Yorum Ekle
  8. HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: adım 8, 3 resimden 1. HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: adım 8, 3 resimden 2. HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: adım 8, 3 resimden 3.
    • Pry the back plastic casing off with your hands.
    FixBot'a Sor
    Yorum Ekle
  9. HTC Rhyme Volume Button  Replacement: adım 9, 2 resimden 1. HTC Rhyme Volume Button  Replacement: adım 9, 2 resimden 2.
    • Use the tip of a screwdriver to push the button out of the panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Frederick
119 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 9-6, Leahy Fall 2014 USF Tampa, Team 9-6, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S9G6
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 501
