Ana içeriğe geç
HTC SMT 6175 Ear Speaker Replacement
Neye ihtiyacın var
  1. HTC SMT 6175 Ear Speaker Replacement, Back Case: adım 1, 1 resimden 1.
    • First, flip the phone over so that the back is facing upwards.
  2. HTC SMT 6175 Ear Speaker Replacement: adım 2, 2 resimden 1. HTC SMT 6175 Ear Speaker Replacement: adım 2, 2 resimden 2.
    • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
  3. HTC SMT 6175 Ear Speaker Replacement, Battery: adım 3, 2 resimden 1. HTC SMT 6175 Ear Speaker Replacement, Battery: adım 3, 2 resimden 2.
    • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
  4. HTC SMT 6175 Ear Speaker Replacement, Speaker: adım 4, 2 resimden 1. HTC SMT 6175 Ear Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Next, choose the matching tool from your driver kit and remove the six screws found around the perimeter of the phone.
    • Once the screws are removed make sure to keep them in a safe place for reassembly.
  5. HTC SMT 6175 Ear Speaker Replacement: adım 5, 2 resimden 1. HTC SMT 6175 Ear Speaker Replacement: adım 5, 2 resimden 2.
    • Carefully pull off the back casing.
    • This can be difficult. Start by slowly pulling the back part from the front shell. As it starts to lift up, continue moving around the phone until it is in two separate pieces.
  6. HTC SMT 6175 Ear Speaker Replacement: adım 6, 1 resimden 1.
    • Next, remove the top screw.
    • Be careful! The LCD screen is still attached to the front of the motherboard by a flexible ribbon cable.
  7. HTC SMT 6175 Ear Speaker Replacement: adım 7, 2 resimden 1. HTC SMT 6175 Ear Speaker Replacement: adım 7, 2 resimden 2.
    • Flip over the motherboard so that the front case is visible. Using a spudger, remove the speaker out of its holding cell.
Sonuç
Luke Plewa
116 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-29, Garner Spring 2011 Cal Poly, Team 25-29, Garner Spring 2011 üyesi
CPSU-GARNER-S11S25G29
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,713
